C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Nick Williams 102mm Throttle Bodies
Old 03-25-2010, 01:07 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default Nick Williams 102mm Throttle Bodies
Nick Williams is known for making some of the highest quality throttle bodies on the market. This is a great addition to the FAST LSXR 102mm Intake Manifold.
Nick Williams 102mm Throttle Body (Drive by Wire) $575
* New LS2/LS3/LS7 version
* No harness required
Old 04-12-2010, 10:23 PM
DSOM Z06
DSOM Z06's Avatar
If only you didn't need an MBA to tune them...........
Old 10-12-2010, 01:23 PM
0HinsonSuperCars
Former Vendor
We haven't had any issues with tuning for them.
Nick Williams TB Modifications
DTC 121 - Increase minimum temp for test on - Engine Diag, General, Temp Enable, Set to 256
DTC 2119 - Disable
DTC 0068 - Disable via higher RPM for test
ECU TP% output will be between 85-88%. First C6 Auto install we did showed 85%.
ETC Scaler is normally set at 4725. Increase this to max of 7800 or higher.
Idle RPM
If the idle is high, go up on ETC.
If the idle is low, go up on the minimum airflow table.
Seth
Old 10-12-2010, 02:00 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
W havent had any problem tuning the new or old one.
Old 10-12-2010, 02:19 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The older ones took a little bit of work but the new style is a dream to work with.
Old 10-12-2010, 03:01 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Agreed. The older style was a tad harder but wasnt impossible like a few people have said. The new ones are cake.
Old 10-12-2010, 03:13 PM
IANIL8
IANIL8's Avatar
I'm glad you talked me into waiting for the new style it was well worth it's weight in gold... Looks amazing...picked up some nice numbers on the dyno... VERY GOOD MOD...
Old 10-12-2010, 05:11 PM
HNK
HNK's Avatar
Any benefits other than the simplicity of tuning it over the old style?
Old 10-12-2010, 05:35 PM
0HinsonSuperCars
Former Vendor
The old style required a harness, this one doesn't. The new one also looks better. Here's the old one.
Seth
Old 10-13-2010, 08:07 AM
JG853
JG853's Avatar
Any performance differences between the old and the new version? I would suspect no other than easier to tune... Please advise
Old 10-13-2010, 09:48 AM
0HinsonSuperCars
Former Vendor
No performance difference.
Seth
Old 10-13-2010, 10:09 AM
jjtoma
Support Corvetteforum!
jjtoma's Avatar
Default In Stock ?
Do you have these in stock. Or what is delivery time.
Jim
Old 10-13-2010, 01:19 PM
0HinsonSuperCars
Former Vendor
Jim
Yes, we have them in stock ready to ship. I'll need your zip code if you need a delivery date.
Seth
Old 11-10-2010, 03:30 PM
0HinsonSuperCars
Former Vendor
Thanks for your orders!
Old 11-10-2010, 05:11 PM
CraZee ZO6
CraZee ZO6's Avatar
send me your best price for this tb and a lsxr 102 fast
Old 11-10-2010, 06:00 PM
0HinsonSuperCars
Former Vendor
PM sent.
Old 11-10-2010, 06:18 PM
HoustonSVT
HoustonSVT's Avatar
What kind of performance benifit could one expect?
To Nick Williams 102mm Throttle Bodies
Old 11-11-2010, 04:15 PM
webcarconnection
webcarconnection's Avatar
PM me price for LS7 engine with shipping to P.R. (zip 00901)
thanks
Old 11-11-2010, 05:39 PM
0Myhardtop
Former Vendor
Myhardtop's Avatar
Seth,
I just tested one yesterday, the quality is top notch and install was a breeze.
In the case of my car, I didn't have to do anything...NOTHING!!!! I repeat, NOTHING. The car idle settled and drove like nothing was changed; I was very impressed. It took some playing with on the older units but these new ones are like a hot knife on butter...easy
Dyno results thus far: I gained 10HP and 9TQ to the tires and still testing. On the streets, the car runs crisper and pulls harder!!!
Remember, my car is modded to the max which typically means that it takes a good mod to see and feel a difference and we did. The wife, one of my test driving lab rabbit drove it and said it felt crisper and the gear changes transitions are much more smoother with much better stop light take off.
Also on the streets I noticed something unexpected, it seems to clean up any little roughness, it drives much smoother even while luggin' it in 5th or 6th going 40mph or less.
I'll give credit with credit is due: Great job Seth, I like it...you have a PM.
Thanks,
Carlos
Old 11-11-2010, 07:09 PM
DSOM Z06
DSOM Z06's Avatar
Originally Posted by Myhardtop
Seth,
Thanks,
Carlos
Now THAT is good news as I just placed my order!!!!
Quick Reply: [Z06] Nick Williams 102mm Throttle Bodies
