C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 325 vs. 345 rear tire
Old 05-05-2010, 07:19 PM
bright1984
bright1984's Avatar
Default 325 vs. 345 rear tire
Hey guys, I just got a flat in my rear tire and looking for some options in terms of non run-flats. I'm looking at Nitto Invos in particular. It seems that a lot of people go with a 345 rear tire instead of the 325 stock size... Why is that??? Besides costing a bit more, does 345 fit/perform/ride better? It looks like both will fit the Z, so which size should I go with and why, if you would.
I'm looking to place an order tonight so any quick feedback would be greatly appreciated!
Old 05-05-2010, 07:37 PM
racerx8
racerx8's Avatar
I just put a set of 295/345 Invos on my Z06 w/stock rims. I only got to put about 20 miles on them before foot surgery but I like them.
The fronts on a 9.5" rim are ok (maybe a bit pinched), the rears 12" are fine.
Ride is excellent, low noise I like them. I'll probably put 275/325 Invos on my C6 coupe.
Old 05-05-2010, 08:19 PM
blkz
blkz's Avatar
I run 295/345 PS2 for increase contact patch , no issues on the track
Old 05-05-2010, 08:32 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,430 Likes on 599 Posts
St. Jude Donor '08
No issues either, just better handling and a quieter ride.
We also run Kumho V710's in 285/335 and Hoosier A6's in 295/345 on factory rims without any issues or major rubbing.
Old 05-05-2010, 10:46 PM
bright1984
bright1984's Avatar
So, any reason at all not to go with 345s in the back?
Old 05-05-2010, 11:19 PM
BLW BY
BLW BY's Avatar
Contrary to popular belief, I'd stick with 275/325's.
A 345 is 20mm wider than a 325, that's .8 of an inch.
Drive through a puddle of water and tell me your contact patch is 20mm wider, hardly.
Why carry the extra rubber and weight around if you're not getting the benefit.
It's great to see so many doing it, makes my car faster without doing anything.
There are more reasons too, but this should be enough for you to make an informed decision.
Old 05-05-2010, 11:21 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,823 Likes on 1,145 Posts
The 325s weren't available yet when I bought mine last year.
Old 05-06-2010, 07:04 AM
bright1984
bright1984's Avatar
Interesting take. Thanks for your thoughts.
Old 05-06-2010, 07:22 AM
GOLD72
GOLD72's Avatar
Received 1,156 Likes on 744 Posts
That's been the problem for the past four years and why 345's have been bought and installed as a substitute to the GY EMTs.
Old 05-06-2010, 09:35 AM
C5 Frank
C5 Frank's Avatar
Just make sure you are going to get all four tires. If you try to run nonrunflats on the rear with runflats up front.... you wont be to happy!!! The car will not handle right.
Old 05-06-2010, 09:58 AM
CJ1957
CJ1957's Avatar
If you are thinking about rear 345 Michelin PS ZP's (Zero Pressure run-flats), there is a slight difference in width vs the GY run-flats but, they are actually slimmer than the 325 GY's.
I bought the PS ZP's mounted to new aftermarket rims in stock size 12X19 and look at the photo below (the Michelin is on the right). The tire pressure for both was 30 PSI. I was surprised that the GY's were wider. From what of been told by tire folks (Discount Tire) not all tire sizes are equal to all manufactures. I guess Michelin felt it should brag about being bigger when they truly aren't.
Old 05-06-2010, 01:56 PM
BLW BY
BLW BY's Avatar
You're Welcome!
Anytime
Old 05-06-2010, 04:20 PM
TAILWAG
TAILWAG's Avatar
EXACTLY...same w/the invos. The Invos in 345 are slightly narrower than the 325 GYs...the 335 NT05 is just about the same as a 325 GY...it is all over the place.
I wonder how the PS2 345 is in coparison to the GY...I will check tonight...
Old 05-06-2010, 07:17 PM
PatriotZ
PatriotZ's Avatar
Location: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Good info here....thanks
Old 05-06-2010, 07:45 PM
bright1984
bright1984's Avatar
I already put in an order for 345 Nittos Invos this morning, so if I wanted to replace the original front tires (275 GYs) with Invos, would I need to get 295s since 275 Invos would be narrower than the original GYs??? Would 295s be too wide for the front?
To 325 vs. 345 rear tire
Quick Reply: [Z06] 325 vs. 345 rear tire
