Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake How-Tos
- How to Remove/Replace Front Brake Pads
Step by step instructions for do-it-yourselfers.
- How to Replace Rear Brake Pads
- How to Replace Front Brake Calipers
- How to Replace Rear Brake Calipers
- How to Replace Brake Disc
[Z06] DIY: Changing brake pads on stock calipers + Removing rotors
#41
If it was defective pads then the problem would have moved to the inboard side of the caliper... Sounds AND looks like your guide pins are touching the rotor... I know you said that none of them are worn but to me it looks like something is missaligned whether it is debris behind the rotor or the caliper isnt mounted properly.
Also are those guide pins factory? I didnt know GM changed the design to standard style 6 point bolts.
#42
Imagine having a GS Conversion just completed and NOT being able to drive it for a STUPID reason such as this problem!! Its killing me Anyway, here are some pics of the car a few days ago...
#43
Are these stock GM rotors??
DH
#44
#45
hubs are clean.... dont have stock pins... wish I did and if I buy them, its one expensive way to test the problem lol- But if it comes to it and I dont have a choice, obviously I will.....
#47
It seems like all the feedback I am getting is pointing towards the guide pins... The pins are by RB EZ Bolts (Racing brake) they are engineered and designed specifically for the C6 Z06 Calipers. Many people here on the forum use them with no problems.... from what I have researched-
Cool car
#48
Dude...look at the location of the pins and the deep cut into the rotor as they are an exact match, it appears that the culprit = pins...you may need to go to stock pins.
#49
#50
I use a wood clamp to compress the cylinders back in place.
Great write up.
I did a search for wood clamp
http://www.bing.com/shopping/1hsj-si...amps&FORM=HURE
Great write up.
#51
RB EZ pins and hawk pads
#52
#53
they are aftermarket pins by Racing Brakes... I ended up putting about 70 miles on the car... just driving it, applying brakes.. bedding them.. the whole nine. I am happy to report that the screeching has stopped for the most part... I say that because occassionally when I make a FULL turn, you'll hear something scraping (that metal to metal sound) for 30 to 45 seconds and then it disappears again... So, I think with all the feedback and techs on the phone and physical/visual inspections, I have decided to just drive the car... put a few hundred miles on these new rotors and pads and monitor what happens... but we did find out: IT WAS DEFINITELY THE RACING BRAKE AFTERMARKET PINS THAT WERE MAKING CONTACT WITH THE ROTORS. We made sure everything was properly torqued, mounted, installed and we made sure that the area where the caliper bolts go through were not powdercoated and they werent. So, I now have to decide what to do regarding the whole formal complaint process with RB pertaining to the pins. Im just not the type of guy who likes pursuing these types of things.. they're prolonged and verry difficult to succeed in....
#55
Good idea on compressing the caliper pistons using a ratcheting clamp with rubber jaws.....however, I did it with the new padlets in place. Since the clamp has rubber jaws, no damage to caliper or pads AND the little nubs on the padlet backing plates ensures that the pistons are not pushed in too far.
However, all was not well......any tips on getting the rear calipers off? I could do the front calipers after turning the wheels full lock so I can get a really big breaker bar (a "cheater" pipe made it easy) on those tight caliper bolts, but the rear calipers really limit the size and leverage. Any ideas here besides getting the car on lift and cranking away underneath it?
#57
Received 8,929 Likes
Easiest is to use an impact wrench. Also the bolt head size is 21mm not 13/16. Depending on how accurate the socket is you might find a 13/16 socket a little too tight to get on the bolt.
Another way is to use two open end wrenches linked together to give you more leverage.
I know one person who broke the bottom bolt loose by getting his breaker bar at just the right angle downwards followed by lowering the car until the weight of the car on the bar broke the bolt loose. Nothing like using gravity to do your work for you.
Bill
#58
I second that, I was able to do these with my bare hands. Only brake calipers I've ever compressed that way.
#59
Both rear tires off, in neutral, lay under the car, spin rotor 1/4 smack, repeat until it comes loose. I dead blow hammer helps. It too about 5 complete turns (20+ hits) to get the rears off my 14k mile Z. Pretty decent workout.
