C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Dry Sump Fill Cap Stuck
Old 10-31-2010, 03:22 PM
marcar
marcar's Avatar
Default Dry Sump Fill Cap Stuck
Changing the oil and cannot get the fill cap removed. I turned it about 180 degrees and would have to force it to turn further. Is the cap fully threaded on or do you feel for a detent and tug off? Silly question but don't want to have to replace it.
Old 10-31-2010, 03:27 PM
Joe C5
Joe C5's Avatar
No threads. Probably just a little stuck. Wiggle it some and it shoud come out.
Old 10-31-2010, 04:44 PM
marcar
marcar's Avatar
Many thanks for the advice The cap is under a lot of back pressure and it literally popped up into my hand as I was wiggling it free.
Old 10-31-2010, 05:16 PM
GOLD72
GOLD72's Avatar
Received 1,131 Likes on 732 Posts
After 180 degrees, you are at the detent and it should now come off. Might need to wiggle it a little. There is an o-ring underneath the cap to seal and it must be a little balky. It is not fully threaded.
Old 10-31-2010, 05:38 PM
marcar
marcar's Avatar
Thanks for all your help
Cap removed. This is my first oil change with a dry sump system but it's still pretty straight forward. I have the car up on Race Ramps up front and roll ups at the rear. The front ramps are the 67", two piece and I am using the Xtenders as well. I highly recommend these products. The rear ramps allow me clearance to roll my floor jack with cross beam adaptor in place to the desired chassis support location. I like to jack up the rear so it's level with the front allowing better oil drainage.
To Dry Sump Fill Cap Stuck
Quick Reply: [Z06] Dry Sump Fill Cap Stuck
