[ZR1] New cup tire cost & longevity
I saw this post in C7 section
Made me wonder if for 2012 you can get the new lightweight wheel with the old tires? At least for the drive home and the break in period brake burnishing etc. IMO it seems excessively expensive to use 2/3 of the life span of a $4000 set of tires before you ever approach the redline or enjoy doing a over steer through a high speed corner.
Nice to have traction when you need it but what about taking a florida vacation and having to add 4 grand to the trip just to cover tire expense. ....... I would not even want to be able to afford that unless I was already making some HUGE donations to charity.
My club (East Tennessee Corvette Club) just went through the Bowling Green plant Monday. Great tour as usual.
We were treated to a special viewing of the 2012 ZR1 with the optional "Cup" racing tires. These tires are good for about 3000 miles on the street! Replacements go for around $900-$1100 each.
Tom
Tom
If the tire life is a concern to you then it is not for you. You better off getting a second set of wheels/tires.
We'll see what price them come at when they are avaiable..I'm finding it hard to believe they will be close to 1K per tire.
Neither Michelin or TireRack have them available yet in 335/25ZR20... You can probably guestimate from the other available sizes. I saw one (brand new) yesterday in 335/25/ZR20 - it looked half worn out with a treadwear rating of " 80 " .
I think they could easily be $800 or $900 each. Take a look at the info below from Tire Rack's website. You can see that there are several sizes of the MPSC+ N-Spec tires that are approaching $700.
I think the one for the ZR1 will be even more limited in sizes - only ZR1 to start with. Also, it's a ZP (Zero Pressure - Michelin's term for "runflat"). So, I bet it will certainly be their most expensive streetable tire!!!
So.....we'll have to wait and see what they will cost when they become available - but it ain't gonna be cheap!!!!!
Bob
Pilot Sport Cup+ (Plus) / N-Spec Track & Competition DOT radials...... Pilot Sport Cup+ and N-Spec tires were developed for enthusiasts who participate in track day events, as well as for serious drivers on the road. Homologated as Original Equipment (O.E.) on the E92 BMW M3 and Porsche 911, GT2, GT3 and GT3 RS models, Pilot Sport Cup+ / N-Spec tires meet all the requirements for road use as well, however they are not intended to be driven on extremely wet roads with standing water where there is the risk of hydroplaning, or in near-freezing temperatures, through snow or on ice.
305/30ZR19 (102Y) Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “(Y)” = 186+mph (300kph) $628.00 (ea.)
325/30ZR19 (101Y) Load Index 101 = 1819lbs (825kg) per tire
Speed Rating “(Y)” = 186+mph (300kph) $698.00 (ea.)
Speed Rating “(Y)” = 186+mph (300kph) $697.00 (ea.)
315/25ZR20 (99Y) Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “(Y)” = 186+mph (300kph) $677.00 (ea.)
Bob
I used to change $150 DR's every 700 and thought that was excessive
Now as far as the new wheels being available with the old tires..... from the original release I did not get that impression. Does anyone know for sure? If so I can afford their wear rate
Huh????
What size do they have for 660.00??? Is that for each front tire? What does the rear size cost?
I looked all over their website and didn't see any MPSC ZP tires at all.
Can you direct us to more info, maybe a link to their site showing that pricing and what sizes are available?
I didn't think you could get these tires anywhere yet.
TIA,
Bob
TIA,
Bob
I could get almost 10K miles out of sport cups on my Porsche with quite a bit of track use. On the street they should last longer with a good alignment. I bought a set at the track, after cording the old ones, and drove 250 miles home to discover the nibs still on the tread!
I ran the stickiest P tires I could get on a pro tour 96 SS and got 7500 -8000 from them .......... and that was some pretty hard miles on a 4000 pound plus car.
i would rather get their real race slicks at that price and it will ourperform them on the track @550 per rear tire
I agree but then there needs to be a truck and trailer....... then before long you might as well just build a dedicated track car
Received 3,836 Likes
"Ask Tadge" Producer
I can almost guarantee that here in VA, those Cup tires wouldn't last a year. The pavement material we use here is sandpaper-like. I could roll into the gas station for my annual inspection after the first year and they'd laugh me out of there because of the lack of tread.
Other states may be different.
jas
I have the factory Sports Cups on my ACR and after 2000 street miles they aren't showing too much noticable wear. I'm betting about 8-10K out of them with no tracking. But I plan on tracking it this summer some so they'll be shot much quicker.
If these wear slow enough to warrant a good 8-10k miles I'll buy some for my ZR1.
When I got my car within 100 miles I had paint chipped off behind the wheels. Had everything clearbra'd after that.
The tires look like you dipped them in bread crumbs when they are warmed up, they are that sticky.
I'll tell you one thing tho...they are stickier than hell great for the track but if you're planning a lot of street driving you better put something on the wheel wells and rockers because they pick up every grain of sand and throw it against the car.
Location: Deerfield, Illinois Turn On, Turn In, Track Out
I used MPSCs on my Z06 and loved them as a tire I could use to drive to and from the track. I had them on a second set of stock Z06 rims and I did not use the MPSCs as daily driver tires, but I know that many do. I usually track at Autobahn in Joliet, IL. Autobahn has a 2.2 and 3.5 mile configuration, with a lot of tight corners (22 corners on the longer track).
The tires wore significantly more on the outer edge, even cording my fronts at the outer edge while there was plenty of inner tread left. This was with the stock alignment. I then went to -1.5 all around and had somewhat better wear but I know they could use even more camber. I bought some used MPSCs for the fronts that were used on a Porsche in the rear. The Porsche wear was much more even, wearing the inner more than the outer edges but more even across than my tires, but I have no idea what camber was used on the tires and I know it is apples to oranges with 911 vs vette weight, etc. After 2 track days at Autobahn in the ZR1 the outer edges of the 2 left PS2ZPs are already showing significant wear compared to the rights.
I think a good solution may be the Pfadt camber kit if it is usable on the ZR1 (the website says Z06 with no mention of ZR1). That way you could dial in all the aggressive camber you would need for the track and then dial it back out for improving street tire life, whether it's for MPSCs or PS2ZPs. $350 for the kit plus install is way cheaper than the cost of the Michelins. Does anyone have experience with this kit in the ZR1?
Also, for JVP and others that run R comps in the ZR1, how are the tires holding up re: wear and are you still running stock alignment?
When I got my ZR1 I swore I'd track it in stock form but the damn bug is already hitting me!
jas
