C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] New Invos on the rear - handling problems
Old 08-30-2011, 02:19 PM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
Default New Invos on the rear - handling problems
Yesterday afternoon I had new Invos installed on the rear to replace the bald GY runflats. All seemed well until I hit the highway and noticed that the car now follows every rut, joint and bump in the road requiring constant input to keep straight. Even 50mph on smoothish roads is a handful. Under power it is also "darty", unpredictable and borderline dangerous. The car was recently aligned to OE specs and it handled fine before the new tires.
I did keep the front GY Runflats since they were recently replaced (previous owner) and have a decent amount of tread left. Could this problem be because of the runflat/non-runflat mix?
I've mixed different brands on other cars (front/rear only - including Vettes) with no ill effects but I've never had runflats before this car.
Thanks!
Old 08-30-2011, 02:24 PM
blacktavert
blacktavert's Avatar
Probably because of mixing runflats with non runflats
I have Invo's front and rear with no problems
Old 08-30-2011, 02:36 PM
Mr. Gizmo
Mr. Gizmo's Avatar
Thanks!
I would not be mixing the runflats on front with non-runflats in back. I would also be reluctant to mix tire brands with different tread patterns on front and back.
Other than traction issues in cold weather - under 60 degrees, I am satisfied with the stock gy run flats as an all around tire.
Old 08-30-2011, 02:40 PM
RedZ-06
RedZ-06's Avatar
Well my Invos are back ordered 3 weeks, but I'll let ya know what happens when I put mine on. I'm doing the same thing. Replacing rears first and a month later was going to replace fronts....
Old 08-30-2011, 02:41 PM
Ragtop 99
Ragtop 99's Avatar
Received 1,213 Likes on 699 Posts
The Invos have soft sidewalls compared to the GY runflats. You might try a few pounds more air and see if that helps. When I switched, I ran mine a few pounds high to get use to them.
Old 08-30-2011, 04:36 PM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I've never heard that kind of feedback on Invo's... in fact what you described about your Invo's was EXACTLY how my stock OEM runflats felt, and that is with Runflats front and back.
I'd be willing to bet money your experiencing this because you have different tires on the back and front.
Different Tread pattern
Run Flat combined with non-runflat
Different compound material in both tires
The profiles are different for both sets of tires as well. Ditch the front runflats and Run Invos all around. BTW what PSI are you running front and back?
Not a good idea to run 2 different sets of tires, especially on a high performance car.
Old 08-30-2011, 05:08 PM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
At the moment I'm running ~28psi front and ~31psi rear cold. With the GYs I preferred 30/30 and I could feel when they were 2+psi off. I should redo the pressures to see what happens.
The different tread pattern and compounds never seemed to be an issue on other Vettes as long as the tires were the same class - all-season, summer, winter, etc. I'm not talking about pushing the envelope, only low speed cruising. I can see how runflats would be a significant difference, though.
I guess I'll play with the pressures a little bit and if that doesn't fix it then I'll order a set for the front. Too bad I may have to throw away a few thousand miles of tread, though.
Old 08-30-2011, 05:53 PM
383vett
383vett's Avatar
Received 1,547 Likes on 1,046 Posts
Change to Invos up front and sell the GYs. Better eat a couple of bucks than end up in the wall.
Old 08-30-2011, 06:26 PM
abstruse1
abstruse1's Avatar
I'm running Invos F&R, never a problem.
Old 08-30-2011, 06:45 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,762 Likes on 1,119 Posts
Never a good idea to mix tire types. I've had Invos all around for almost two years now, and never had a problem. My Goodyear fronts still had some tread left, but I figured it was better to be safe than sorry.
Old 08-30-2011, 06:53 PM
TORQJNKY
TORQJNKY's Avatar
Invo's all around with no problems.
Old 08-31-2011, 11:10 AM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
I ordered a set of fronts this morning from Discount Tire Direct so I should have them by next week.
It looks like my fronts are down to the bars in the center so they are shot anyway. I should have reached in a little farther when I checked them earlier - could have saved myself a little dough doing them all at once. Oh well.
Thanks for the info everyone!
Old 08-31-2011, 10:03 PM
erikszr1
erikszr1's Avatar
.......bottom line...dont mix tires....period
Old 08-31-2011, 11:20 PM
jlvink66
jlvink66's Avatar
I have Invo's all around and I have way less issues with trammeling than the GY runflats. They are also very good in the rain on the street - no hydroplaning. I don't recommend using them on the track for a rain tire though; I was doing 360's at LS earlier in the year.
John
Old 08-31-2011, 11:32 PM
z10
z10's Avatar
Another voice on Invos. 9000 miles Hugh improvement over the GY's. I'll bet I get at least 20k miles out of them. Love em.
Old 09-01-2011, 12:46 AM
VetteVinnie
20K is a stretch. I am at 16K and the rears are about done. I can maybe get another 1K out of the rears, but only if I take it easy on them. Fronts are probably good for another 5K at least.
Old 09-01-2011, 08:27 AM
sengli
sengli's Avatar
I had the same set up you did for about 1000 miles. I replaced my rears with invos due to the run flats were wore out. Ran the stock runflats on the front. I kinda noticed the same thing you did, but the roads I drove weren't cupped all that bad. Finally had the Z up on a lift one day and saw the inside edge of the front fun flats had steel belts showing thru... When you looked the fronts from the outside of the car they looked fine, and seemingly had alot tread left. So now I have all set of invos all the way around.
To New Invos on the rear - handling problems
Old 09-01-2011, 10:04 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
I got 17k on my Invos before I switched to the cup tires and they weren't worn out yet.
__________________
Contact:
(e) zach@katechengines.com
Old 09-01-2011, 11:11 AM
VetteVinnie
Then stop driving like a grandma and burn some of that rubber.
Old 09-17-2011, 12:38 PM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
Update
I had the new fronts installed last week and the handling is back to normal again. I just did a 1200 mile trip and they were smooth and little quieter than the old Goodyears. The overall grip is better as long as it is warm outside.
Thanks, all!
Quick Reply: [Z06] New Invos on the rear - handling problems
