C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Opinions please...looking to tackle the LS7 "problems".
Old 12-29-2011, 08:09 PM
triblk6spd
Support Corvetteforum!
triblk6spd's Avatar
Default Opinions please...looking to tackle the LS7 "problems".
In a nut shell I have the car pretty much the way I want it in regards to the looks AND performance. I am now set on tackling the LS7 specific problems in regards to head problems and valve/guide issues. Here is my plan...
-Remove the heads
-Replace valve guides with bronze (what brand??)
-Check stock valves and guides for wear...replace any worn valves (OEM or other??)
-Obviously post any findings here.
-Reinstall heads with new ARP hardware and gaskets (OEM or something better *Cometic*)??
Other random questions:
-Will this address the weak link AT my current power level..640 rwhp?
-Should I replace my valve springs that came with my LPE GT19 cam with 689 lift!!...they have ~15,000 miles and ~4 years on them?
-Is there anything else you would consider attending to..keeping in mind I'm not trying to make more power..just make the power I do have more reliable.
Old 12-29-2011, 09:20 PM
1320IN9
1320IN9's Avatar
my opinion if it's not broke dont fix it, in the future if it does break then build it better stronger and faster.
Old 12-29-2011, 09:35 PM
screaminchevy
screaminchevy's Avatar
Since you have an 07 (as do I) I think it's a good idea to do all of the above and have your needle bearings/rocker arms checked. My heads are getting cnc'd right now and I'm swapping out exhaust valves, guides, and rocker arm upgrade. It just gives me peace knowing that's not a weak point anymore more since I like to drive it hard!
Old 12-29-2011, 10:00 PM
Dirty Howie
Dirty Howie's Avatar
Good luck and waiting to hear about guide wear
DH
Old 12-29-2011, 11:03 PM
triblk6spd
triblk6spd's Avatar
Right! The trunion upgrade was one of the first mods I did. What did you use (brands) for guides, seals, lash caps, valves and where did you source them?
Old 12-30-2011, 12:23 AM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
-Remove the heads
Sounds like good preventive maintenance idea on your part, especially on a forced induction application.
Make sure you get a good 5 angle valve job and I would use the same bronze guides as WCCH, and may as well just send your heads to Richard at WCCH, and tell him what you have in mind. You can also contact Carlos at Vette Air, as he is offering a complete upgrade on heads for a good price, and you can't go wrong with him either (he really knows these LS7s).
And while your doing all this, CERTAINLY, replace your valve springs, its just good cheap insurance, and since your approaching 20,000 miles on them makes A LOT of sense (and its inexpensive).
Old 12-30-2011, 12:31 AM
0Cunningham Motorsports
Former Vendor
Cunningham Motorsports's Avatar
send your heads to Richard at WCCH, he works these heads all the time, i wouldnt bother porting them being your supercharged, but definitely upgrade the guides and exh valves... i can almost guarantee you that your guides are already worn out of spec, its very common on all ls7 heads... replace the springs cheap insurance
Old 12-30-2011, 12:57 AM
triblk6spd
triblk6spd's Avatar
Ok good advice. Since Im not porting or polishing do I NEED to send them out or could a good head guy here in Austin do the guides and whatnot?
Also, the spring set that LPE put (and sells) for my GT19 cam is over $$1100! http://www.lingenfelter.com/mm5/merc...gory_Code=P016
Old 12-30-2011, 01:10 AM
Former Vendor
Also, the spring set that LPE put (and sells) for my GT19 cam is over $$1000!
a good cylinder guy should be able to take care of you... just make sure they dont screw up the valve job, had a machine shop do that once.... texas-speed has springs that will work just fine for your cam for half the cost, but the same quality
Old 12-30-2011, 02:38 PM
triblk6spd
triblk6spd's Avatar
Texas Speed offers two set of 700 lift springs...both have to have the head modified for them to fit. Seems maybe I should just do the damn LPE spring kit and save the hassle of modding the heads. ???
Old 12-30-2011, 02:42 PM
AirBusPilot
AirBusPilot's Avatar
Wow, those are some high dollar springs. I'd first have the open and closed spring pressures checked and see if they are still in spec. Might call LPE too and see what kind of life they are getting.
Old 12-30-2011, 03:14 PM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
I'd replace the GT19 cam with a blower cam and save some money and probably make more power.
Old 12-30-2011, 05:39 PM
screaminchevy
I went thru Richard at WCCH. Not sure what brand he uses for the hardware. If I had a larger budget, I'd have sent them to Larry Widmer at ENDYN. If you've never heard of him, he was the guy that created the badass super swirl heads that Bob Gliden used to set all the pro stock dragster records in the 70s. His shop is in Fort Worth and he's been known to get his custom head design to run 17.1 compression on 93 octane...
Old 12-30-2011, 09:20 PM
Michael_D
Michael_D's Avatar
I'm still not convinced there is an inherent "problem" with LS7 guides, all guides wear. It's just the nature of the beast. But, there is enough chatter to motivate me to pull mine and inspect them. And while I have them off, might as well have them worked....it never ends.
LSK lobes (which is what the GT19 uses) have very aggressive opening / closing ramps. They are hard on valve train components, especially springs. The Ferrea spring is a very good spring, which is why LPE recommends them with these cams. I doubt you will find its equal for much less. PAC might have a set, I dunno... I suspect you will also find the guide clearance is in the weeds. The OEM rockers have a fairly small sweep up till about .620 lift, then they start to migrate from center and start side loading the guide. I'd be hesitant to run that much lift without moving to an adjustable rail system with roller tips, but they aren't exactly cheap and require the pedestals to be machined down and re-tapped. Then of course the other big consideration is valve weight running those lobes. If you move to a solid SS valve, you'll need more spring and that in itself has its own can of worms. LPE will tell you to run oem (or comparable) sodium filled valves to keep weight down. Personally, I think Ti is the way to go and think of sodium filled valves as hand grenades with the pin half pulled jsut waiting for an opertunity to pop out the rest of the way, but this adds another $600 or so to the bill.
This is just a thought, but you might be better off going with a new cam, verses dumping the coin on new Ferrea's and dealing with the headaches that GT19 brings. That cam wasn't really intended to be for boost anyway. I suspect that Geoff at EPS could grind you a custom stick with less lift that would make more power and add a bit more reliability. I like his lobes. They gently set the valve down on the seat to keep it from bouncing, but yet still have fairly aggressive off seat ramps between .50 and .200 for better under curve performance. Sometimes less equals more when you have more stable valve events.
I would not send your heads to just anyone for guide replacement and seat / valve work, especially when working with Ti. Seeing how you aren't terribly far away from Arlington, you might want to pay Darin Morgan at Rehre Morrison a visit. I've had several conversations with him about working my heads, and he's been very forthcoming with details and recommendations. He’s a straight shooter who won’t try and baffle you with BS. You might be surprised to hear what he has to say. He also has different port designs for these heads depending on what your goals are. You don't hear much about R-M in on the forums as they stay plenty busy with pro-stock builds, but they do plenty of street / strip builds and are very familiar with LS engines. Just a thought...not a sales pitch.
I prefer the oem gaskets. I also have a preference for studs over bolts, but they can make in-car head swaps a bit more challenging. ARP is good, but not the best. Definitely good enough for these power levels.
Valve guide brands are all over the place... each shop will have their favorite supplier and they'll use the most appropriate alloy for the intended use (there's many different bronze alloy's and each have pro's / con's). I have had good luck with SI and Rev guides. I've also heard good things about CHE, but have no personal experience with them.
Watch your boost if the short block is stock. Get much over 6 with the OEM pistons and cylinder sleeves and you may regret it.
Old 12-31-2011, 03:03 AM
triblk6spd
triblk6spd's Avatar
Wow thats a lot of info! I had to read it twice. Thanks for the good read. Im hoping I can have the heads gone thru and continue to run the same cam with a new set of springs..prob use the same Ferrea stuff LPE put on back on day one. Like I said I dont plan on making more power and I dont feel like the power I do make is out of safe territory.
Where would I find a good set of Ti. valves to replace my OEM ones?
Old 12-31-2011, 04:55 AM
0C_Williams@RPM
Former Vendor
C_Williams@RPM's Avatar
We do a fair amount of LS7 heads and the typical upgrade and reliabilty options looks like this...
LS7 Cylinder Head Reliability & Upgrades
Cylinder Head Components
• Phosphorous bronze valve guides (CHE)
• Stainless steel, one-piece Exhaust Valves
• Upgraded rocker arm trunions
• Competition dual valve springs
Cylinder Head Labor
• Competition Multi-Angle Valve Job
• Install guides and hone to size
• Bowl Porting and Blending
• Mill & CC Combustion Chambers
Additional Cylinder Head Options
Complete CNC cylinder head porting
Intake manifold & throttle body porting
Titanium exhaust valves
Head studs
Also - the GM intake valves are generally great (Del West) but occasionally the coating will wear and they need to be replaced. Two of the best are Del West and Xceldyne - links below
www.delwestengineering.com
www.xceldyne.com
Old 12-31-2011, 08:43 AM
Mopar Jimmy
St. Jude Donor '06
Great stuff William (RPM),
Out of curiousity what is basic cost for a customer to send in their stock LS7 heads and have the first 2 categories done (basic reliability upgrades and labor)?
Thanks in advance.
To Opinions please...looking to tackle the LS7 "problems".
Old 12-31-2011, 08:51 AM
Random84
Random84's Avatar
Originally Posted by Michael_D
I like his lobes.
That's a new one....
Old 12-31-2011, 10:42 AM
0C_Williams@RPM
Former Vendor
Thanks in advance.
$1295 - includes all parts, machining & labor - customer needs to send the heads and rocker arms - we will take it from there.
Cylinder Head Labor
• Disassemble,clean inspect and reassemble
Old 12-31-2011, 11:00 AM
AirBusPilot
http://www.delwestengineering.com/pa...ve_guides.html
Valve Guides
All Del West valve guides are manufactured with the necessary tolerances and high quality level so that they can be installed directly into the cylinder head guide bore without additional work.
Guides are manufactured of several materials depending upon your application. Cross holes for addition valve stem lubrication are also available upon request.
Levels of control on critical dimensions:
• OD Diameter ' 0.005mm ( .0002") ' Tighter control is available upon request or if required
• OD Taper ' 0.005mm ( .0002") ' Tighter control is available upon request or if required
• OD Roundness 0.005mm ( .0002") ' Tighter control is available upon request or if required
• OD-ID Concentricity ' 0.005mm ( .0002") ' Tighter control is available upon request or if required
• OD Surface Finish ' Ra0.20microns' Tighter control is available upon request or if required
Material choices:
• Manganese Bronze
• Beryllium Copper Alloys
• Aluminum
• Sintered Iron
Please speak with a Del West engineer to understand what is right for your application.
Del West. Precisely.
Quick Reply: [Z06] Opinions please...looking to tackle the LS7 "problems".
