C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Start Button problem
Old Dec 17, 2015 | 09:47 PM
548chevelle's Avatar
548chevelle
You can help isolate the problem by going to the underhood fuse block. Find the 'crank relay 43' and remove it. Use a piece of wire or a paper clip and insert the ends into the two terminals that would be at the 5 and 11 o'clock positions (or lower right and upper left) The other two terminals are at 1 and 7 o'clock. This will put 12 volts directly to the starter. I have a pushbutton with terminals that plug into these relay terminals that I use for variuos reasons when I need to crank the engine without wanting to have it start.
Old Dec 17, 2015 | 09:51 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Originally Posted by shockwave
Had a similar problem. Starter motor had a bad spot and would not engage or rotate. Replaced starter motor and problem was fixed.
Old Dec 17, 2015 | 10:38 PM
spdmn75's Avatar
spdmn75
the BCM could be taking a crap also.
Old Dec 17, 2015 | 10:44 PM
spdmn75's Avatar
spdmn75
Old Dec 17, 2015 | 10:53 PM
spdmn75's Avatar
spdmn75
Old Dec 18, 2015 | 07:51 AM
dcamick's Avatar
dcamick
That's good stuff!
Old Dec 18, 2015 | 02:31 PM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
I pulled the #43 relay and used the jumper wire and the starter turn. I went out and bought a new replay switch and it didn't help at all the same problem. Any ideas.
Old Mar 17, 2016 | 10:56 AM
C6RAPTOR's Avatar
C6RAPTOR
What did you find to be the problem?
Old Mar 17, 2016 | 12:33 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I've had this happen a few times. I found it was usually when my cell phone was in the same pocket or very close to my FOB that it happened. When it does happen, I simply move my phone somewhere else and then it starts.
I'm thinking the phone is somehow interfering with the signal from the FOB.
Ron
Old Mar 17, 2016 | 02:19 PM
C6RAPTOR's Avatar
C6RAPTOR
Ron
Page 2-5 in my Owners Manual under decrease in remote keyless entry transmitter range it lists interference from electronic devices such as cell phones or lap top PCs.
I think if this is the problem you would receive a DIC warning NO FOBS DETECTED when you attempted to start the car.
If it is a FOB related problem and not a starter circuit problem you could test by placing the FOB in the glove box pocket and see if it will start.
Old Mar 17, 2016 | 03:17 PM
Tech's Avatar
Tech
I had the same problem. Sometimes the gauges would sweep, sometimes they wouldn't. It would eventually start. When it started, it fired right up. A new battery seems to have resolved my issue.
Old Mar 17, 2016 | 04:13 PM
hawkandersonjr
Sorry about the reply time. I found out that my shifter linkage cable connector the one in the console had broken off and the car was still in drive (transmission) but the shift **** was showing it being in park, so it wouldn't start. The weird thing is when I use the replay box to using a jumper wire the car actually started and the engine was running. Thank God I had all the wheels chocked and the hand break pulled. I was all under the car at one time trying to use a screw driver on the starter solenoid glad I couldn’t get to it.
