[Z06] ** "Seconds before disaster video" LS7 valve guide wear, how to check for it **
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,091 Likes
We have been replacing so many LS7 heads lately here that we decided to put a video together of what the damage actually looks like for you guys to see first hand who do not do this stuff regularly.
It seems that almost every LS7 coming in here with 20k or more on the odometer (06-07 especially) has excessive wear and often the owner does not know it. The cars are getting dropped off for a supercharger or cam etc, but we have to start with repairing the heads first. To the point that we have a half dozen rotating LS7 heads in the works at all times now to shorten the wait for the customers.
It has come to the point where we can tell just by listening to the car, if you hold the RPM up to roughly 2k you can hear the play in the drive train. A handful of the owners just thought it's how the engine sounds since they bought the car second hand and are amazed how much quieter it is after repairing the cylinder heads. I do not have a video of that sorry, but here is a video of what the wear looks like itself.
Do you have a video of what it sounds like at 2000 RPM if there is an issue? I have the stereotypical sewing machine noise at 2000 RPM in my car, but I have no idea if that is normal or if it's what you are referring to.
I do not have a video of that sorry, I also do not think I have the proper audio equipment to capture it properly, but I will try and take a video of the next car.
We used to do all our own cylinder head repair work-porting etc and have the equipment, but now we core them out to WCCH. It's just more stream line for the customer that way.
Thanks for the response! Could you give your best guess as to what it sounds like? I get a sewing machine noise between 1500 and 2500 RPMs (after that, the engine noise drowns it out). I'm guessing this is not the noise you are referring to.
Thats about right yes. I would have your heads checked asap. To give a bad example, we had a customer who was already scheduled for this repair just waiting to get in drop a valve last week and grenaded the entire engine. Day late-dollar short...
edit, just to clarify- that IS the noise I'm referring too.
Too many people out there who think this can't happen to them.
It's a very real problem, and one which when you get down to it, is an easy one to fix so that you can drive the car without having to worry about it.
That poor guy was probably out of warranty too, because you say that he was scheduled to have the work done on his heads.
Now he needs a motor.
Of course there will be those who will say that it's all scare tactics. But for many it's yet another warning to be aggressive and proactive when it comes to addressing this issue, or end up regretting it.
Can you share details on how you determined the the 'sewing machine' noise at 2k RPM is a sign of a pending valve train failure and is not just how these LS motors sound?
FWIW, my car with stock heads had the noise. My car with the fixed WCCH2 heads makes the noise. LS7 Drew's car before and after his PRC265 heads made the noise. And there are a few others that still have that noise after the heads have been replaced. There are other LS-based cars with the same noise. I believe my brother's LS6 has a similar noise.
While I do suggest that folks who are worried about a drop should investigate their options, I'm not so sure that the 'tick' is a sign of an issue.
This really makes it tough as to what we should think/do about this problem. Another recent post shows many people with some significant mileage with no problems, with some speculating that this is only a 2% problem. So what is it, 2%, 20% or more??
That's optimistic.
