[Z06] LS7 Cylinder Head Specials
Supporting Vendor
Received 1,016 Likes
American Heritage Performance is a small Corvette Specialty shop in southern California. We have seen our fair share of LS7 heads and have alot of experience reworking the factory castings. We would like to offer the Corvette Forum Members a limited time special offer.
Send your Factory LS7 cylinder heads in to us and choose one of the following packages.
Package #1 includes:
Disassemble and Assembly of cylinder heads
Performance Valve Job
Resurface Heads
Clean and Bead Blast entire head
Replace factory valve guides with Bronze Valve Guides
Treated (tumble polished) stock Titanium intake valves
Solid Stainless Steel exhaust valves (Dart Valves 96 grams)
Total For Package #1: $932 (plus return shipping)
Package #2 includes:
Resurface Heads
Ferrea Competition Plus Exhaust Valves F2042P (85 grams) or Ferrea Super Alloy SS valves F1597P (your choice of Ferrea valves)
Total For Package #2: $1,100 (plus return shipping)
Package #3 includes:
Same as package #1 but instead of bronze vlave guides Package #3 uses new factory Powdered Metal valve guides (Dart exhaust valve)
Total For Package #3: $1,060 (plus return shipping)
Package #4 includes:
Same as package #2 but instead of bronze valve guides Package #4 uses new factory Powdered Metal valve guides (Ferrea F2042P or F1597P exhaust valve)
Total For package #4: $1,228 (plus return shipping)
We also offer porting and polishing of your LS7 cylinder heads via use of our Super Flow Flow Bench at an additional cost of $400.
We also offer Dual Valve Spring kits with Titanium retainers, Machined locks, Seals, Locators and Shims. $300 for our .660" lift spring kits. Give us your actual measured camshaft specs and we will shim your aftermarket spring kit for optimum performance. If you want us to reuse your stock LS7 springs we will install new hat style stock valve seals at no additional charge.
PM us or send us an email via our website for more information or to place your order. Turn around time once we receive your heads to shipping them out is 5-7 days.
http://www.americanheritageperformance.com/
HP@americanheritageperformance.com
This is a limited time offer.
Uploaded with ImageShack.us
Resurface Heads
Resurface Heads
Resurface Heads
Resurface Heads
Ferrea Super Alloy Exhaust Valves (F2042P 85 grams)
Same as package #2 but instead of bronze valve guides Package #4 uses new factory Powdered Metal valve guides (Ferrea F2042P exhaust valve)
Resurface Heads
Resurface Heads
Good to see your shop offering these options for Z06 owners, because there is certainly a demand for them.
Supporting Vendor
here are a few more:
Treated stock Ti intake valve and Dart exhaust valve
Treated stock Ti intake valve and Ferrea exhaust valve
To the vendor: Good to see someone offering PM guides as an option.
Just curious...what springs are you guys using in your package deals? Also, any experience with the Ferrea hollow stem valves they developed earlier this year?
Supporting Vendor
Yes we have used the Ferrea Hollow stem valves (F2042P) in a few builds with very good results. We have found our track oriented customers more drawn tword the F2042P valves. We offer both the Ferrea Super Alloy SS exhaust valves (F1597P) and the Ferrea Competition hollow exhaust valves (F2042P) in our packages (same price point to the customer).
What are the flow numbers after the port work, the weight of the valves and do you have a install package deal ( gaskets crank bolt and such)?
American Heritage Performance did my head work, porting of my TB and Intake Manifold, Cam swap and LT Headers... Couldnt be happier with the quality, price and turnaround time!
Great shop!
Great shop!
For the LS7, I have always asserted the machining of the guides were faulty.
I've never said they were necessary. Proof? How about thousands, if not millions, of solid stainless exhaust valves in high lobe lift, high RPM engines in more applications than not? Seems like they've worked well for a long time. Do you have proof otherwise? No, no you don't.
BTW sodium filled exhaust valves have been in use with great success since WWII.
Glad were on the same page then. I guess I mistook your trollish post for something else then.
Very nice to see another player in the market...THANK-YOU!
I also echo the comment about it being very nice to see the option of factory PM guides being available.
Cheers, Paul.
Cheers, Paul.
I have a couple of questions for you, please.
1. Do you have a preference for PM or Bronze guides?
2. Do you use the same BT spring kit for both exhaust valves?
3. What are your guide to stem measurements after completion?
5. What do you think the problem is with the stock cylinder heads?
DH
DH
