C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Spitting A/C Belts - ATI Super Damper
Old 09-02-2022, 05:24 PM
  #141
???'s Avatar
Originally Posted by Tony @ Mamo Motorsports
That said the dampeners with the taller guides are still being made for me.....the nice thing about this is minor misalignment issues are no longer issues.
With the really short guide on the current 10% U/D unit, even a really small amount of a misalignment can potentially become a problem. The taller guides are going to eliminate that scenario
I not sure that's 100% true. my brand has high sides and it threw the belt at the last session of a track day, had been fine for years before that. once it's tossed one it tossed them all. if you spend enough time searching Google you will find just about every ls based car board has some belt throwing thread 50 plus posts long, anything from stock to aftermarket balancers and when it throws its a crap shoot as to what it takes out.
the much better way than trying to cover for the problem with higher sided pulley which might work forever or might not. finding a way to align the compressor while you're under there, is much safer way imo.
either way, it's such a relief when it finally stops. hopefully everyone finds a way. probably the most annoying thing I've ever dealt with in 30 plus years of breaking and fixing cars haha.
Old 09-04-2022, 04:43 AM
  #142
Supporting Vendor
Tony @ Mamo Motorsports's Avatar
I'm confident it will eliminate most of the belt toss problems....if you have a significant misalignment or a defective tensioner it might not but there is a reason GM decided to make the belt guide as tall as they did (which is .150 ish tall....same height I have spec'ed for this custom part number I'm working with ATI on)
The 10% U/D ATI is only .060 tall....a significant reduction in height. With the OEM height the top of the belt is even with the top of the guide....it would take alot more things wrong to toss a belt with that situation than with a much smaller guide.
Looking at how a belt sits with a .060 tall guide, most of the belt thickness is above the guide (which is difficult to even see at that point)
Given the choice its a no brainer to go with the design with the OEM guide height....the only thing I'm trying to accomplish with this custom piece is to offer myself, my clients and other's interested that choice and peace of mind.
Time will tell how effective it is but I have put my money where my mouth is by investing in a much larger quantity to enable this to actually happen.
The new dampeners should be ready soon.....the outer custom shells (with the taller guide) are actually done....my last update from ATI we were simply waiting on the hubs to be machined
-Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
SeanDon210 (09-05-2022)
Old 06-27-2023, 11:02 PM
  #143
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,713 Likes on 1,089 Posts
I must have unsubscribed from this thread at some point because I stopped seeing the updates. I've been through two other C6s since this problem (2010 ZR1 and now a 2011 Grand Sport vert). It's wild to see that this thread has stayed going for almost a decade (and here I am helping it along - but I can do that since I'm the original author ).
@Tony @ Mamo Motorsports , did they ever get the updated part released?
Old 06-27-2023, 11:10 PM
  #144
Supporting Vendor
Yes.....I finally got the new design ATI dampeners and they have been working great. I have sold about 15 so far and not a tossed belt from anyone
I posted this new thread about it awhile back.....the pictures show you all you need to know about why the original design was a problematic and why my new design (mostly copying what GM intended here) is the cure.
Do me a favor and bump it to the top while your there!
https://www.corvetteforum.com/forums...-ac-belts.html
Regards,
Tony
Old 06-28-2023, 10:14 AM
  #145
VetteVinnie
Regards,
Tony
Thank you. And done. I didn't see it because I sold the Z06 in 2015 (it changed hands again in 2016, and that owner posted above), and I sold my subsequent ZR1 in 2021. My current Grand Sport kept me away from the Z06/ZR1 section. I'll be sure to visit more often.
EDIT: It looks like my Z06 changed hands again in 2018, so hopefully the current owner finds his/her way here: https://www.corvetteforum.com/forums...-for-sale.html
Old 04-14-2024, 04:50 PM
  #146
RapidC84B
RapidC84B's Avatar
Received 13,212 Likes on 6,018 Posts
Just bought a 2006 Z for track build with a spit AC belt… guess I need to replace the damper with Tony’s.
Quick Reply: [Z06] Spitting A/C Belts - ATI Super Damper
