C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wiring Diagram
Old 08-07-2014, 09:07 PM
RLVette
RLVette's Avatar
Default Wiring Diagram
OK, the guys over on the Cadillac Forum won't help, so I'm hoping one of you can help. My neighbor has a 2003 CTS V6. I'm pretty sure the antenna module has went bad causing the battery to go dead after not being driven for a day. I pulled the 10 amp fuse marked truck release and the battery stays up. The antenna module and the trunk release work off the same fuse. The Cadillac dealer wants $616.00 plus tax to replace the antenna module. I'd like to disconnect the antenna module while keeping the trunk release working. There is no keyed lock for the trunk lid. I've googled for a wiring diagram but not had any luck. Maybe one of you have had the same problem?
Old 08-07-2014, 09:47 PM
erick_e
Support Corvetteforum!
erick_e's Avatar
St. Jude Donor '13-'14-'15-'16
Not sure if this is the one you need.
File Type: pdf
Old 08-07-2014, 11:09 PM
RLVette
RLVette's Avatar
I'll have to check the car to see if the wire colors add up.
Thanks Erick
To Wiring Diagram
Quick Reply: [Z06] Wiring Diagram
