C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] couple modifications =)
Old 08-13-2014, 05:47 PM
cruzc5frc
cruzc5frc's Avatar
Default couple modifications =)
ARH 1 7/8" Headers w/Cats, a Katech Heat Exchanger, 160 Tstat, and an LPE upper pulley
Still strapped in, will post numbers when available
Old 08-14-2014, 04:56 PM
gearbox
gearbox's Avatar
Sick!
Old 08-14-2014, 05:17 PM
cruzc5frc
cruzc5frc's Avatar
Pretty impressed with the numbers for such minimal conservative mods!! Next steps may be completing the LPE 710 package or maybe LPE 750, or a local shops equivalent.
Old 08-14-2014, 07:42 PM
need4speedmotors
Supporting Vendor
need4speedmotors's Avatar
Beast !
That's great numbers for what you had put on.
Old 08-14-2014, 07:53 PM
billetman
billetman's Avatar
Do you have a readout with the fuel as it looks like it stops pulling clean at around 6100 rpm might be some even better numbers lurking in there.
Old 08-14-2014, 11:54 PM
cruzc5frc
cruzc5frc's Avatar
will check that out, another small issue is when braking for a light and in neutral the motor drops below 400 rpm and sometimes blips itself back to 1500 then to 600, but sometimes can all the way die. Probably an easy tweak when I get it back to the tuner. Its intermittent and I can usually heel toe blip it if I see it going below 500 or so.
To couple modifications =)
Quick Reply: [ZR1] couple modifications =)
