C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] BTR stg IV Cam
Old 12-28-2014, 06:18 PM
95vettski
95vettski's Avatar
Originally Posted by v8sten
Here was my car around lunch time yesterday, It took all in all about 8-9 hours to do the install. we just copied a tune from a friends car that has the Stage III cam to get it to run. so with a copied tune, until can get it properly tuned the 5th, it sounds pretty good. My car has Frankenstein Stg 2 LS7 casting heads, K&N CAI, BTR Stg 4 cam, Monster Dual disc clutch, MGW shifter, stock exhaust (for now). ill post a sound clip once tuned
Should make some steam
Can you share more details about the heads? Flow numbers and what size?
Old 12-29-2014, 12:27 AM
C6Antwon
C6Antwon's Avatar
Mine will be on the dyno tomorrow night. I'll post up a thread with #s and mods tomorrow night!
Old 12-29-2014, 12:35 AM
v8sten
v8sten's Avatar
from what i could gather over the phone (i was at work), @ the lift I am at (.650ish) they flow 390 cfm on the intake and i forgot what they said the exhaust flowed, with their CNC porting program, New Manley Severe Duty exhaust valves, new bronze guides, BTR Platinum valve springs with titanium retainers. Frankenstein said it should make well over 600 to the wheels with the stage 4 cam and intake and full exhaust.
Old 01-03-2015, 01:02 AM
C6Antwon
C6Antwon's Avatar
Well she made 596whp 540wtq on a Dynojet AWD dyno at Covert a Tuning Dynamics here in Columbus, OH
Mods:
-Livernois Stage 3 (IPS) Heads
-BTR Stage 4 LS7 cam
-LG Super Pro headers & x pipe
-Borla ATAK Axle Back
-PeakSpeed ported FAST 102
-Vararam
-NW 102mm throttle body
-Cloyes Timing Set
-3/16" Livernois Pushrods
-Polished/tumbled OEM rockers w/trunion upgrade
-ARP Head Studs
Old 01-03-2015, 02:56 AM
v8sten
v8sten's Avatar
Mods:
-Vararam
-Cloyes Timing Set
-ARP Head Studs
Are you running a Fast 102 intake?
Old 01-03-2015, 08:52 AM
double06
double06's Avatar
Default Dyno Graph
Is the 474 and 450 tq the stock starting spot?
Old 01-03-2015, 09:54 PM
C6Antwon
C6Antwon's Avatar
Yes I am, sorry I edited it.
Yes, it made 474 with:
K&n intake
LG Super Pros
Stock bimode exhaust
Tune
Old 01-04-2015, 08:46 AM
Z06 Steve
Z06 Steve's Avatar
nice numbers! whats the mill on the heads?
Old 01-04-2015, 11:34 PM
C6Antwon
C6Antwon's Avatar
Cleanup mill, about .005-.008. Power is from the cam and porting, not compression really. I could deck them and run meth or race gas, but that wasn't the goal.
Old 01-05-2015, 12:05 AM
v8sten
v8sten's Avatar
mine goes on the dyno tomorrow to tune it, ill post the results tomorrow.
Old 01-05-2015, 06:22 PM
v8sten
v8sten's Avatar
Found out today that they are Stg 1 Frankenstein LS7 heads and that the are milled .030" to bump the compression up to 11.5:1. The exhaust ports on these heads are no longer a "D" port, they are now round. With my car having stock manifolds there is some turbulence or may be some revergence causing it to knock above 6K RPM and to pull timing out, also could be bad gas or a combo of the two. I'm running this tank out to put some Shell 93 octane, then go back and tweak on it a little more.
550 RWHP @ 17 degrees isnt to bad
2007 2LZ
Frankenstein Stg 1 CNC ported LS7 heads
BTR Stg IV LS7 N/A cam
K&N CAI
MGW shifter
Monster Dual disc clutch with master cylinder and slave cylinder
275/345 INVOS
Bottomed out stock bolts
Mild2Wild
Old 01-06-2015, 08:21 PM
C6Antwon
C6Antwon's Avatar
Nice numbers!!! Can't wait for better gas and more timing!!!
Old 04-12-2015, 06:46 PM
  #33
soldier4life
soldier4life's Avatar
Any updates on this cam? Looking to buy it, but want anyone info comments suggestions, eTc.....
Old 04-12-2015, 07:46 PM
  #34
v8sten
v8sten's Avatar
I just ordered my headers and will go back for a retune once installed. hopefully ill be close to the 600 rwhp mark. driving it everyday, its a lotta bit jerky. i had pretty great luck at tx2k15 and whooped up on a slew of 650-700 rwhp cars and was told that i had a supercharger. they were stupefied when i opened the hood and they saw stock manifolds, stock spark plug wires, generally a stock engine bay other than a k&n cai. this cam pulls like a freight train above 3500 rpm. if the "jerkiness" doesn't bother you then go for it. if you want a smoother ride and still make some good steam look into the stg 3 cam, that cam makes great power too and is more street friendly.
Old 04-12-2015, 08:58 PM
  #35
soldier4life
I'm hoping the jerkyness can be tamed through tuning. I expect some bucking. It's either this or Katech k501 cam. Think only the stage 4 is a closer comparison with the k501but I could be wrong. I need to look at a stage 3 and see the specs. I had a tourqer 110 in my last Z06 and loved it, but hated how it died up top. I'm willing to give up some low end TQ for a freight train top end....
Old 04-12-2015, 10:56 PM
  #36
v8sten
v8sten's Avatar
with the 111 +2 its gunna be hard to tame the jerkiness. I too will give it a go once I get a new laptop and my own hp tuners. it doesnt really bother me and I am happy with it. I have put about 8K miles on this car since the cam install.
Old 04-13-2015, 08:47 AM
  #37
LS7 BUD
LS7 BUD's Avatar
I have the stage 4 BTR cam and my car runs smooth... Only a tiny bit of surging at 1300-1500 in 1st-4th... Zero bucking in 5th or 6th at any rpm... I'm 12:1cr...
To BTR stg IV Cam
Old 04-13-2015, 11:08 AM
  #38
v8sten
v8sten's Avatar
so there is hope
Old 04-13-2015, 11:14 AM
  #39
Racingswh
Racingswh's Avatar
Received 1,078 Likes on 647 Posts
was told that i had a supercharger. they were stupefied when i opened the hood and they saw stock manifolds, stock spark plug wires, generally a stock engine bay other than a k&n cai..
I agree as most will that headers with this cam is important.
I love that second part!! That's great!! I always find it funny when you hear the speculation that's so far off as justification for why someone got stomped. The truth is hard to deal with sometimes.
Nice work!!
Old 04-13-2015, 11:32 AM
  #40
v8sten
v8sten's Avatar
Here is a little vid of my car
Quick Reply: [Z06] BTR stg IV Cam
