C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] MSD airforce intake + 20 flywheel over fast
Old 01-14-2015, 11:44 AM
meinersk
meinersk's Avatar
Default MSD airforce intake + 20 flywheel over fast
Was just on the phone with MAST motor and asked what else can I do to my z06 besides heads and they mentioned they tested msd unported vs fast unported on a 675 flywheel hp ls7 and got additional +20 flywheel hp...Other companies will be testing also, so I will wait for their results..But it sounds good to me..
Old 01-14-2015, 02:45 PM
lt1z
lt1z's Avatar
Interesting. Too bad the manifold cant really be portmatched like a fast can as I imagine some will line up better then others depending on the heads or production tolerances and effect the potential gains
Old 01-14-2015, 05:27 PM
meinersk
meinersk's Avatar
Well Im waiting for other shops to play with it and see what happens. ported vs ported is all that matters really to me. But even ported fast might not compare..
Old 01-14-2015, 06:07 PM
Fifedogg
Fifedogg's Avatar
If it picks up at least 10 HP/TQ over a ported FAST I will be buying one for sure.
Old 01-14-2015, 06:59 PM
EX1
EX1's Avatar
Peak gains are cool and everything but you need the rest of the powerband.
Old 01-14-2015, 08:06 PM
double06
double06's Avatar
Default Power Band
I agree on the power band and what it may look like. It would be good if it was like 20 hp over a 1500 rpm band and then maybe 10 hp over another 1000 rpm. Based on the Lingenfelter chart it appears equal to about 4,500 rpm and then the delta begins to show between the 2 manifolds. Drivability will be another issue especially down low but we should see a few of these in the next 2 months and can figure it out then.
Old 01-14-2015, 08:15 PM
ZR1X
ZR1X's Avatar
Default Port matchining
Too bad it can't be port matched like the FAST? How do you think they used to port match intakesbefore multi-piece composite ones were made. The LS style manifolds locate better than any other past GM manifold. Any one can port match intakes these days.
Old 01-14-2015, 09:25 PM
C6z06man
C6z06man's Avatar
I've heard the same thing. Curious to see some people's results. Loos like a good piece.
Old 01-16-2015, 10:03 AM
meinersk
meinersk's Avatar
I agree.....thought I would say what I was told..maybe some members will wait on msd instead of spending their money now..
Old 01-16-2015, 01:39 PM
lt1z
lt1z's Avatar
I guess I should have said as easily as a FAST. Anyway, I have one on order to test. The MSD rep told me they could not have removable runners due to a FAST patent on that design. They would have if they could.
Old 01-24-2015, 10:43 AM
RX-Ben
RX-Ben's Avatar
Mast dyno -
Old 01-24-2015, 12:48 PM
meinersk
meinersk's Avatar
Originally Posted by RX-Ben
Mast dyno -
I was told 20 flywheel by mast..This looks like more
Old 01-24-2015, 03:21 PM
double06
double06's Avatar
Default Pretty good difference
Looks like about 30 ft pounds of tq and 40 hp peak to peak. The delta starts at about 4,500 rpm with the big difference after 5,500 rpm.
Old 01-24-2015, 06:33 PM
lt1z
lt1z's Avatar
So that is an LS7 manifold vs the MSD?
Old 01-24-2015, 08:14 PM
double06
double06's Avatar
Default Manifold
According to the graph sub-names I would say yes.
Old 01-25-2015, 03:58 PM
Da Z06
Da Z06's Avatar
Real solid gains, no losses down low with huge gains from 4500 up, hell where do I sign!
Old 01-26-2015, 01:27 AM
x88
x88's Avatar
Don't know about that, graph begins at 3500 and it does appear to have some loss
To MSD airforce intake + 20 flywheel over fast
Old 01-26-2015, 07:18 AM
double06
double06's Avatar
Default Graph Difference
I do not know at 3500, I can not tell which line is which since they seem to parallel for about 500 rpm.
Old 01-26-2015, 08:08 AM
Da Z06
Da Z06's Avatar
Correct, we may not be able to make a true assessment of the graph down low since they are the same color. But Ill give 10lb of TQ down low for some 20+RWHP on top any day.
Old 01-26-2015, 04:57 PM
x88
x88's Avatar
I would agree 10 for 20, but 20 for 20 I am not so sure I would. Hopefully once results start coming in we can get a better idea of what to expect
Quick Reply: [Z06] MSD airforce intake + 20 flywheel over fast
