C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Mods and driving for tune
Old 03-19-2015, 05:13 AM
SuperchargedTundra
SuperchargedTundra's Avatar
Default Mods and driving for tune
Is it safe to drive 45min away for a tune with the following mods after being installed?
C&C milled heads
cam
headers/intake/exhaust
102tb and fast or msd
Old 03-19-2015, 08:34 AM
vertC6
Support Corvetteforum!
vertC6's Avatar
I know for sure you want to leave the stock throttlebody on till you get to where you're going, how much do you plan the mill?
Old 03-19-2015, 09:10 AM
Z0-SICK
Z0-SICK's Avatar
It's definitely pushing it. With what you have just invested in my opinion not worth the gamble. Overnight your ecm to them with your head and cam specs so they can at least dial that in, before you drive there for dyno time. Or see if someone from the shop can come to you and street tune your car or tune it enough to drive it to their shop. If you drive it like this you'll put a lot of stress for too long. You'll definitely be running lean and seeing knock which for that long a period can damage your engine.
Old 03-19-2015, 09:16 AM
NHRA95
NHRA95's Avatar
Get it flat bedded to the shop!
Old 03-19-2015, 09:29 AM
etekberg
etekberg's Avatar
Easy answer: Use that super charged tundra to tow it to the shop.
Old 03-19-2015, 02:11 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
As others have stated...go with at least a mail order tune and take it easy on the drive there if the above aforementioned method won't work.
Old 03-19-2015, 03:24 PM
SuperchargedTundra
Thanks for the input guys. I'll have to start looking around for a trailer to fit it on. I saw a few guys on here loading them up on a uhaul rented trailer.
Old 03-19-2015, 03:26 PM
etekberg
etekberg's Avatar
Where are you located? You can borrow mine.
Old 03-19-2015, 03:29 PM
SuperchargedTundra
Appreciate the offer brother!
I'm in upstate NY (Albany area) though. I would def take you up on it if you were close.
Old 03-19-2015, 05:22 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,762 Likes on 1,119 Posts
Tow it! One bad detonation, and there goes the engine. Don't gamble away a $15,000.00 engine.
Old 03-19-2015, 06:24 PM
telly444
telly444's Avatar
will it even make it that far with no tune? Mine stalled every 5 min and surged like crazy. no chance in hell I was driving anywhere without a baseline tune.
Old 03-19-2015, 07:24 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Driving it won't be bad, issue will be stop lights/etc. Getting it to idle and not stall will be the issue. The rest of the stuff isn't ideal, but wouldn't hurt anything.
Like Telly said, the driveability will be the issue, not safety of the motor.
Old 03-19-2015, 09:19 PM
Z06 Steve
Z06 Steve's Avatar
What shop for the dyno?
Old 03-19-2015, 10:03 PM
SuperchargedTundra
Was thinking about Coppola Motorsports in Saratoga
Old 03-20-2015, 12:31 AM
richie427
richie427's Avatar
DONT drive it anywere flat bed it. or like some one posted up get a base tune, an even, that would freak me the f--- out. I am new in here, should be some one on the east coast that will chime in with better info. So anyways you did all that work your self, or you got help, the parts you picked up some one must of told you. what needs to be done after the install, my guess. Sorry dont want to come across as a a$$ hole.
Old 03-20-2015, 12:34 AM
SuperchargedTundra
If someone told me I wouldn't be asking on here
Old 03-20-2015, 07:46 AM
Z06 Steve
Z06 Steve's Avatar
i'd say it depends on the size of the cam and if you can make a safe trip. My widow r cam needed a mail order tune as it wouldnt hold an idle..... then I drove it 2.5 hrs to Slowhawk in Ma. Copolla charges too much Slowhawk is alot cheaper and you get a street and dyno tune. Hes big on ls1tech
To Mods and driving for tune
Old 03-20-2015, 10:13 AM
Unreal
Unreal's Avatar
Never seen a tune from base go in and add a ton of fuel and pull a bunch of timing. The stock tune is so conservative. You land up pulling fuel, and adding timing, and part throttle, as long as you have enough fuel trim, it won't hurt anything unless you did 12:1 compression. Like I said, idle and stop lights will be rough, low RPM freeway maybe rough, but as far as exploding from knock/etc, just don't see that happening. I wouldn't go over 50% throttle, but limping it to a shop is fine if you can.
Exceptions would be real high compression, or swapping injectors without a tune.
Old 03-20-2015, 10:18 AM
08mojo
08mojo's Avatar
I agree. Limp the car there, if possible, and you'll be fine. If the tuner is able to provide you with a base tune, that will definitely get you to the shop. Just baby the car, no WOT or heavy load, and you'll be okay.
Old 03-20-2015, 10:43 AM
0Myhardtop
Former Vendor
Myhardtop's Avatar
You can drive it, it will run like crap at stop lights to stop lights, but you can manage. Don't go (WOT) Mad Max on it and take it easy...on the hwy, don't use cruise control and don't do make any take over moves, just keep her at a steady cruise and you should be fine.
Hope this helps
Thanks,
Carlos
Quick Reply: [Z06] Mods and driving for tune
