[Z06] DIY 3" Muffler Mod
Wish I had the welding skillz necessary to pull this off! Congrats, that is a *way* stealthy mod! Hope you get some b2b dyno numbers soon! Can't wait for the video. thanks!
I figured it would sound like the Fusions open, they are 3" straight pipe too
Best $200 you'll ever spend on your Z!
Picture of the tip modifications
(2) 76mm Exhaust Control Valves, SS, Closed style, $40 each
http://www.aliexpress.com/snapshot/7...70138975749301
I also noticed they are coming from China, how long did it take to get yours?
Here is the link for normally open
http://www.aliexpress.com/store/prod...789782919.html
Thanks for the reply and making this DIY. Our welding skills appear to be on the same level, well you might be more advanced than me. It was a huge PITA to weld the skins back on my mufflers when I modded them. The grinding wheel was absolutely needed in my case.
I was just wondering, arent the valves normally open. the link you posted is for normally closed.
The only margin note on reusing the Pierburg actuators is that the triangular bolt circle of the Pierburgs are smaller in diameter than the 76mm butterflies, so you have to file/drill the holes towards the inside by about 2mm each. Then, no fitment issue, completely the same operation as the stock NPPs, only more evil.
v8sten (11-18-2015)
No MTW???? Pull the fuse while its running so we can hear the difference at idle
#33
Fair point, I found a similar "before" mod video, I'll put them together. Didn't I send you a PM regarding GS seats for sale, I don't recall a response? I love the new exhaust, sounds much throatier, cackles and pops on decel now. Looking for other peoples feedback as well.
#34
im gunna order the valves tonight and the piping shouldnt be an issue to get. once it all comes in im gunna do this either over Thanksgiving or Christmas, whenever the parts get here
#35
That's awesome man. The 60 degree bend with the 3" CLR is critical, any longer of a radius and the pipes wont be able to make the turns tight enough inside the can. I could only find one company selling the 3" CLR, all others were like 4" or 5". One more note on the Chinese actuators, the vacuum nipple is facing side to side, and the factory hose connects from the rear. The hose would probably stretch far enough to make the turn, but something to think about. I'll make sure I have those how to notes prepared before Thanksgiving.
v8sten (11-18-2015)
#37
I though about the CLR on the way home, I just opened CF up and saw your comment, thanks that helps a lot
#38
Sounds healthier with the 3in upgrade. It's gotta be making more power, at least a little more.
#39
Ordered the valves, looking for the pipes, gunna see if i can get them local
****** EDIT ******
Everything is ordered, it was a little more than you stated. So far I am at $259.68 in parts to be exact, not including shop supplies
****** EDIT ******
#40
The only two tools that are specific to the job are the 3" holesaw and the 3/4" holesaw (for the 4 bypass holes 3 inches foreward of the baffle). Both holesaws are available at Lowes, I went through two of each, you can save by buying one with an arbor each, and another blade only of each. If you have a drill press one holesaw each will last, but I had a hand held drill that allowed the holesaw to "walk" slightly and it put too much heat on the cutting edges and wore out faster. Locking it all in place will make the tools last, lots of WD40 on the saws, obviously. I'll put the notes into the how-to. Seemed like I couldn't go 45 mins without somekind of hurdle that was unanticipated, hoping to have other people avoid the unanticipated stuff.
Looking forward to see your project, I can't stop driving my car today, just happy with how it sounds now, like a Z06 is meant to sound.
jasonz28camaro (11-18-2015)
