C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] No oil pressure after first start up - heads/cam
Old 03-16-2016, 09:27 PM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
Mine read XXX after my head job. Found the connector was not fully seated.
Old 03-16-2016, 09:43 PM
548chevelle
548chevelle's Avatar
What's a good way to prelube?
Old 03-17-2016, 01:41 PM
Cman01
Cman01's Avatar
https://www.corvetteforum.com/forums...-is-it-ok.html
post #9
Old 03-24-2017, 09:47 AM
MTBSully
MTBSully's Avatar
What was the resolution of this? Started up my build last night and have the same issue. Hoping I didnt tear the oil pan gasket
Old 03-24-2017, 09:59 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
you guys that do this yourself are some bad ****'s.... I cannot imagine attempting to do that... I only wish that I had those kind of skillz.....
Old 03-24-2017, 10:13 AM
Cha_Cha
Cha_Cha's Avatar
Fill oil pump with oil thru the plug on the left side of block so it doesn't spin dry, I use a 3/8 hose and a funnel. Seal that back up and hit ignition switch to crank motor with clutch and gas pedal fully depressed. It will not start until you let off gas pedal. To stop cranking just hit ignition switch as if you were turning off car. Never had issue with this method and had oil pressure immediately upon startup.
Old 03-24-2017, 10:22 AM
MTBSully
MTBSully's Avatar
Was going to try this next. Did you thread in a special fitting to get the 3/8 hose in there?
Old 03-24-2017, 10:30 AM
Cha_Cha
Cha_Cha's Avatar
No.
Old 03-24-2017, 11:20 AM
1badtantrum
1badtantrum's Avatar
This may be a bit extreme but a heater blanket on pan/dry sump tank to warm things up and a Peterson Remote Mount w/ primer does a great job. I installed this on my 2009 Z06 track car in place of the windshield washer tank.
Old 03-24-2017, 11:23 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
The following 3 users liked this post by realcanuk:
Da Z06 (03-25-2017), Dan_the_C5_Man (03-24-2017), MTPZ06 (03-24-2017)
Old 03-24-2017, 11:30 AM
MTBSully
MTBSully's Avatar
Originally Posted by realcanuk
Will give this a try tonight. Would be awesome if my problem was as simple as that. Who knows. This galley plug is just below the alternator, correct?
Old 03-24-2017, 11:32 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Correct. I actually prefer to pump oil through the whole engine with a pump, but this way should get the job done unless something is really wrong.
Old 03-24-2017, 11:48 AM
  #33
MTBSully
MTBSully's Avatar
I have a pump, will do my best to rig something up, and go from there.
Old 03-24-2017, 12:28 PM
  #34
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Air pockets can be difficult to clear. I would also try the gallery plug method.
Old 03-24-2017, 12:52 PM
  #35
rio95
rio95's Avatar
I had the same problem until I plugged the sensor in haha
Old 03-24-2017, 01:14 PM
  #36
MTBSully
MTBSully's Avatar
Why is everyone unplugging the sensor? During a heads/cam swap I saw no need to unplug mine. Unless it somehow became unseated when I swapped the manifold on, which i dont see how it could as it is an automotive snap style connector.
Old 03-24-2017, 01:22 PM
  #37
rio95
rio95's Avatar
Shoot now that you say that I think it was actually the coolant temp I was thinking. Whatever is on the right side of the block I didn't have plugged in
To No oil pressure after first start up - heads/cam
Old 03-24-2017, 01:24 PM
  #38
MyLS1Hauls
MyLS1Hauls's Avatar
Depending on what manifold you use, and how the sensor is oriented from the factory, some need to me clocked, so the connector isn't hitting the manifold. I ended up having to use an additional washer, so I could clock mine correctly.
Old 03-24-2017, 01:43 PM
  #39
MTBSully
MTBSully's Avatar
Yeah thats the coolant temp sensor on the drivers side head. Nothing to do with your oil pressure. Which makes your issue stranger haha
Old 03-24-2017, 02:19 PM
  #40
08mojo
08mojo's Avatar
I inadvertently unplugged my oil pressure sensor when I was reinstalling the intake manifold. Was not a good feeling to see 0 oil pressure on initial startup. I luckily found the sensor was unplugged, plugged it back in and all was well.
Quick Reply: [Z06] No oil pressure after first start up - heads/cam
