[Z06] Where to get injector O-rings?
St. Jude Donor '13
I want to pull the intake to port and do a catch can while the intake is off. I'd also like the clean the injectors and replace the o-rings while there.
After several searches I wasn't able to find which size and material o-rings to order for the injectors. Does anyone have the size and material information or a good source of an injector rebuilt kit?
The o-rings are for stock 2009 LS7 injectors.
On a side note:
The injector duty cycle is 95% WOT. Should I bite the bullet and spend the extra money for larger injectors for a ZR1 or other injector recommendation?
On a side note:
MickVette (09-02-2016)
You're certainly pushing it.
St. Jude Donor '13
Here ya go
Seal kit
Seal kit
"The status of your order has changed and we wanted to keep you up to date.
PART UNAVAILABLE:
Our apologies but according to our database, the part or parts you ordered are unavailable at this time. We have now canceled your order and voided out your payment"
Well, it looks like injectors might be a safer option for this car anyway. Any recommendations on brand/size that tunes well with HPTuners? I calculate about a 48lb/hr injector would be a little under 80% duty cycle so anywhere in that range should be fine.
LS9/A injectors. Either those or ID's. If you have an 09 or older, you'll need to scale the tune if you go with ID's. Not a big deal, but I generally do not like scaling if it can be avoided, even if you do the simpler stoic scaling method.
MickVette (09-06-2016)
I don't like pushing the limits of fuel injectors because you're not leaving yourself much room for error.
The thing about buying random o-rings is that you can't be sure of the material it is made (unless it is specified). You want something that is compatible with the fuel you are using, especially important if you are running anything alcohol based.
I purchased my lower o-rings from Lingenfelter and the uppers I bought directly from the manufacturer of the injector (Bosch). Not cheap, but cheaper than having problems.
St. Jude Donor '13
ID is VERY proud of their injectors!!!! OUCH!
For the record I wouldn't install random o-rings and thank you guys for all the good information. Much appreciated.
I thought the same thing. You're really paying for the injector data. Lots of similar injectors will work... it's the data that ID provides that makes tuning a snap.
And that they are a top notch injector with excellent service. I would only use OEM gm injectors or Id.
St. Jude Donor '13
Agree the injector data is very valuable and means so much to the outcome of the tune. Without it you are doing some trial/error and getting close at best.
I WAS saving for a rear spoiler. Might end up putting that toward injectors instead. Not sure the injector bang for the buck will be worth the cost in the long run for a NA car that is almost as far as I plan to take it modification wise. Im at 95% duty cycle currently. The only thing I have left to do is port match the intake tot the heads. I'll get a more controllable injector duty cycle with bigger injectors but wonder if the increase over stock injectors will be worth it.
Anyone here "been there, done that" have any wisdom to share? My mind is open.
Just get some used LSA/9 injectors in that case.
On a side note:
On a side note:
MickVette (09-07-2016)
Injector Dynamics is the only company that characterizes their injectors. Many other companies try to "steal" their data and use it as their own. FIC is one who has been caught doing that.
So....I have done this, and have learned the hard way to either use OEM, ID, or pay the bucks to have them characterized by Greg Banish.
St. Jude Donor '13
Yes, I have been there. Three different sets for my personal car. Bizare tuning issues that miraculously disappeared when I plugged some IDs in. I have since learned a lot more about why the data is so important. Not feeling like typing a book. Just go to Marcin's blog and read a few of his write ups. http://redhardsupra.blogspot.com/ Won't take you long to realize just how much math is involved. Everything is function based with fueling. If the data is wrong, fueling is wrong.
I have Greg's tuning book. He stresses the importance of injector characterization quite a bit.
MickVette (09-08-2016)
Plus Paul needs to work on his Porsche, so buy ID injectors.
