[Z06] New PB ET, MPH, & 60ft!!!! Pics and Video
Group of friends and I went to Mid-Michigan Motorplex today to take advantage of this nice fall weather. The summary is I drove over an hour to get to the track with my drag wheels, cracked off a 10.0 within 10 min, and then drove over an hour home at the end of the night after making seven passes. Man I love this car!
I was REALLY hoping for a 9 sec pass, but fell a little short AGAIN. Putting it all together is quite challenging as many of you know.
When I first arrived, I aired down my hoosiers to 16 psi and pulled right up with pretty much no cool down and was shocked to pull a 1.41 60ft, along with a new PB ET by a few thousandths of a second. I think if I would have shifted a touch faster, this would have been my 9sec pass, b/c I can't expect to get much or any better of a 60ft.
The track was empty so I could just keep going and going if I had wanted. I made a total of 7 runs and all but one were very consistent (six runs from 10-10.2ish). I managed a best mph of 138.35. The track was shut down for about an hour for repair and then it wouldn't hook afterwards hence the 1.5s at the end.
I think the car has a 9 in it for sure, but I'm thinking about what else I can do to make it a little easier. I'm looking at maybe getting a vette air scoop or switching to a vararam. Even in 55deg weather I couldn't keep the IATs as low as I'd like. A little more WOT street tuning might be worthwhile too. I'll be reviewing scans this week to see where I can improve. If you have any advice, let me know!
Mods are as follows:
Vette air/WCCH stock heads ported and milled (11.8-12:1)
Hell widow Cam
Mamo ported fast
Halltech 107
NW102
ARH 1 7/8" headers and O/R X
BB bullet cat back
RXT clutch
RTS wheels with 315/35/17 hoosier drag radials and skinnies
3,100 pounds with me
DA was about 500-700 all day.
Here's the video, showing all but two runs.
Hell widow Cam
Mamo ported fast
Halltech 107
NW102
BB bullet cat back
RXT clutch
I'm not a drag racer, but now with HCI and an RXT clutch I will try my hand at it a few times this winter down in the valley. You must be happy with the RXT clutch. Very nice runs and great trap speed.
Yeah this clutch has been awesome! I will most likely get another when I need it.
http://racingperformancepartsaz.com/
Check josh b's build thread
He lays out the $400 solution. It's a diy but I'm to cheap to pay for someone else's labor so once i move near e85, I'll be doing that. Or driver mod, i know you're good, better DA and you're basically there. Good luck!
That's bad a$$ !!!
3100 lbs with driver ??!! Damn
The MSD will push you over the top and into the 9's
Those are some killer times. I would do ATI damper over the MSD intake. You don't need a lot. Hell, maybe you just need better DA and you're there.
I'm curious to see what you're launching and shifting at? Also, did you say you drover 2 hours round trip on those hoosiers? I just got a set and didn't want to drive on them cause I heard they wear fast. My track is 35-45minutes away. How long they last you?
I started looking at my scans last night. I found that I left a lot on the table with some of my shifts. Even though they were all NLS some were simply just too slow. On my fastest pass the 1-2 shift was about 0.32s and the 3-4 was about 0.28s. Those just simply aren't going to cut it at this power level. I was shifting faster later in the day, but didn't have as good of a 60ft. If I could piece my runs together it would have been in the 9s for sure haha.
I hold at 2k RPMs, then floor it and at the same time start to slip the clutch. RPMs go up to about 6,500 and I try to not let them fall too far. Keeping the nose up is key!
Yeah over 2 hours round trip. I usually leave my drag wheels on this time of the year. I get sick of taking them on and off. I can get a whole year out of a set with some street and track use. If you used on the street exclusively I doubt you'd get more than 5k miles taking it somewhat easy. I try to keep 25 psi in them on the street to help prevent the inside edge from wearing as fast.
NachosZO6 (10-11-2016)
I'm staying away from ATI until they get their reputation back up.
PRE-Z06 (10-16-2016)
Excellent runs...very consistent. Agree with others...a Mamofied MSD would compliment your combo quite nicely.
