[Z06] wot = damaged piston
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,123 Likes
Hmmm... first to grab the gold ring here.
Sorry for the bad luck OP. Looking at the crack it would appear that the block "should" be able to be resleeved. A tear-down will let you know that. If you're still intent on keeping it supercharged you might consider an ERL shortblock with a set of forged blower pistons at about 9 to 1 compression, depending on your planned ultimate boost. Depending at the level of desired boost you also should consider some stronger rods. At 10 to 12 psi the stock TI rods should hang in there.
I was going to mention, depending on budget and future HP goals, it may behoove the OP to explore an LSX iron block.
So far best quote I have received after tellimg them i wanted 900-1000 whp
was 12-15k depending on what parts I pick, from xp racing 3-4 week build time , new lsx block , machining plus forged internals, cam and head
arp stud kit
worst quote was hennessy performance
1000hp package $75000 and 6 month build time
arp stud kit
arp stud kit
arp stud kit
Criminals. $75K, and you'd get $7500 worth of parts (mostly used/embezzled crap), and 6 months would turn into years. Unless you're a celebrity like Jay Leno, then they roll out the red carpet. Jay gets the white glove treatment, you and I get the rubber glove treatment.
Erl shortblock
Hello.
Looks like you are in the market for a shortblock.
We have a few options in stock and ready to ship for a Z06 Dry Sump setup.
1) Dry Sleeved Shortblock with Compstar / Wiseco internals, rated up to 900hp
2) SuperDeck 4 bolt Shortblock with Callies Dragonslayer/I beam rods and Custom Wiseco Pistons, rated up to 1150hp
Please give us a call for more details and pricing. 1-877-815-3434
arp stud kit
arp stud kit
LME, Livernois, or ERL
Got to decide on what block to run, aluminum or LSX.
Short block should be $8-9k depending on parts.
Can do a forged ls2/ls3 for $4500ish that will take that all day, but then your looking at 376-408ci. If you can live without 427ci, that is a good option. Will need to swap to a small bore head too.
$12-14k for a long block (lsx or erl based) is going to be the norm, plus add in all the other little added expenses.
A 1000hp build is easy $30-40k. Once you get the motor, then drivetrain goes to ****, then other parts. Think long and hard if you want to do that. I would never build another 1000+hp vette.
