C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Shifting @ 7000 and Boom???.....
Old 02-19-2017, 03:59 PM
instg8er
instg8er's Avatar
Default Shifting @ 7000 and Boom???.....
Just able to get the car out some with this good weather we have been having in NC and have notice that if I shift from 2-3 or 3-4 at or near 7000 the car feels like it hit a timing retard or it stalls the motor. some times it will clear up and drive thro it. today i poped back and made a hell of a noise, i let out of it and hit it again and all is good??? Im not sure what he has the rev lim. at but the dyno is pulled to 7400 and i am not going that high.
Any help or any one had this problem?
Thanks for any help. I know i cant have this happen when i spray it in a few weeks is all....
Old 02-19-2017, 05:03 PM
jayyyw
jayyyw's Avatar
In for info. I may be having the same issue.
Old 02-19-2017, 05:27 PM
Patriot Six
Patriot Six's Avatar
It sounds like you hit the fuel shutoff. I would check to see where it is set at in your tune. The tachometer reading may lag behind actual rpms. It has caused me to hit the rev limiter numerous times.
Old 02-19-2017, 05:34 PM
LMB-Z
LMB-Z's Avatar
Sounds to me like you hit the rev limiter. Should be set at 7000, unless its been changed.
Old 02-19-2017, 06:30 PM
Michael_D
Michael_D's Avatar
You'll have to look at the calibration. Both spark and fuel can be used for rev limit.
Old 02-19-2017, 07:10 PM
EnginerdVT
EnginerdVT's Avatar
If it's fuel cut rev limiter, I wouldn't practice that too many times. Even my full bolt-on car outruns the RPM gauge here and there. Don't know your mods, but MANY cars stop making power north of 6500, some less. Is your setup optimized to run that high and make power? Not trying to deny that it sounds like something might be inconsistent.
Old 02-19-2017, 07:54 PM
Michael_D
Michael_D's Avatar
No idea what you just asked me.....
Old 02-19-2017, 08:11 PM
Turbo2L
Turbo2L's Avatar
Are you still on the stock clutch?
Old 02-19-2017, 09:20 PM
instg8er
instg8er's Avatar
Rps BC3
Old 02-19-2017, 09:37 PM
EnginerdVT
EnginerdVT's Avatar
I'll try again without the other comments with my original quote below...
Does your car have parts installed that continue to make more power above 6500 RPM?
"Don't know your mods, but MANY cars stop making power north of 6500, some less. Is your setup optimized to run that high and make power?"
instg8er (02-19-2017)
Old 02-19-2017, 09:49 PM
instg8er
instg8er's Avatar
Yes sir it is.
Old 02-19-2017, 11:05 PM
lamboworld
lamboworld's Avatar
Hope you get if figured it out. I am just curious though, do most of you turn off the clutch fuel cut off. My tuner has turned this off, so my fuel does not cutoff when the clutch is depressed.
Old 02-20-2017, 11:25 AM
Michael_D
Michael_D's Avatar
Not that it matters what my car will do, but yes it will carry power over 6500 rpm. My comments were directed towards the OP's issue and had nothing to do with my car's capabilities.
There are numerous tables in the calibration that control over rev. Depending on where the tuner set them, they may not play nice together. That's why I said what I did. Need to know the current calibration settings before jumping to a conclusion of what could be causing the symptoms the OP described.
If they are set correctly, then bumping the rev limiter is not a problem. If racing a clock, I'd try not to do that, as it'll slow you down, but there is no issue with bumping the limiters - assuming they are set correctly.
Old 02-20-2017, 12:31 PM
EnginerdVT
EnginerdVT's Avatar
Oh I confused you and OP as I'm viewing from my phone. I was quoting your mention of the two kinds but was directing my question on the cars capabilities toward the OP. Sorry for the confusion.
Old 02-20-2017, 12:36 PM
dmuellenberg
dmuellenberg's Avatar
News to me - I didn't know the Z06 had a clutch fuel cut off. I have power shifted many times (keeping the gas pedal to the floor when shifting) and I've never experienced the fuel being cut off. Also you wouldn't hit the rev limiter when missing a shift but that happens. Maybe it is turned off by defualt?
Old 02-20-2017, 04:22 PM
instg8er
instg8er's Avatar
I hope to be home and able to check and see tomorrow night with HPT. But it's going back in the rollers Friday for the 200 shot. And will be address then for sure.
Old 02-20-2017, 04:26 PM
Michael_D
Michael_D's Avatar
No worries.
Clutch fuel cut off can be tweaked for no-lift shifts. Cool if you like that.
To Shifting @ 7000 and Boom???.....
Old 02-20-2017, 05:59 PM
Pinski 1
Pinski 1's Avatar
Sure you aren't spinning? Do you have traction control on? My car was doing the same thing after heads and cam so I thought I was having issues...come to find out, the tires were breaking loose and traction control was kicking in. Hit the T/C button once and no more issues....
Old 02-20-2017, 07:24 PM
instg8er
instg8er's Avatar
I always turn off and hold down do turn off handling also. It's not spinning for sure. It's a fuel cut or timing cut. Feels like the power is stopped and starts stuttering and popping back. I lift and get back in it and all is good.. I have seen a engine drag one time also in the message center.
Old 02-20-2017, 07:42 PM
Patriot Six
Engine drag active means the ECU is giving more throttle upon decel due to larger than stock rear tire sizes in comparison to the front tires. It's hardly noticeable and not the cause for the issues you're having.
instg8er (02-20-2017)
Quick Reply: [Z06] Shifting @ 7000 and Boom???.....
