[Z06] Very loose valve guides.
How much valvetrain noise was made?
Darn, from the video angle loos like .25 movement!!
FWIW I believe this video makes it clear that excessive clearance is not the only contributing factor to dropping a valve.
The wear in that video beat the hell out of that valve. Some valves must be thicker and tougher than others.
Yep, just like any manufacturing process, you are going to get some valves that are stronger than others, and some that are junk. The worn guides increase the stress, but the valve sets what the limit of that stress is.
