Wide Band 02 Sensor
Any "Key On Engine On" 12V source should work fine. I usually look for one that has the same fuzing requirement for the object being powered.
pass side fuse box, under the floor mat up front, is where I've installed mine for power key on. I also had to run a dedicated ground wire to the battery neg terminal to eliminate the hissing I was getting through the speakers when grounded to the dash frame. Just an FYI.
Heated Seats/Wiper is switched.
This will explain it all - you don't need to make the cigarette lighter outlet switched, just read the other stuff:
http://www.kawal.net/poweroutlet.htm
Last edited by nuke61; 03-27-2018 at 10:24 AM. Reason: added info about not needing to do switched cig lighter
