Wheel Fitment
Wheel Fitment
My name is Pauly. I have a 1996 corvette with c6 wheels. I have 19x10 wheels on the rear with 295/30r19 tires. Can I go with 325/30r19 tires without affecting the ABS sensor.
Pauly, you are in the wrong section. Ask this question in the C4 section and I'm sure you'll have your answer in no time
You probably shouldn't run a 325/30 on a 10" wide wheel. Check manufacturer approved rim width before doing that. My guess is the wheel isn't wide enough for that tire.
