C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
what percent of c6 ls7s drop valves?
Old 05-05-2018, 09:54 PM
mdiers
5th Gear
mdiers's Avatar
Default what percent of c6 ls7s drop valves?
Does anyone have an idea of what percent of c6 z06's drop valves?
Old 05-05-2018, 09:58 PM
juanvaldez
juanvaldez's Avatar
Does it matter? Will you buy one if it is 1%? 10%
Old 05-05-2018, 10:03 PM
Sy1616
Sy1616's Avatar
<1% as far as I’m aware.
Old 05-05-2018, 10:07 PM
c5racr1
c5racr1's Avatar
100 % eventually
LTVN68 (05-16-2018)
Old 05-05-2018, 10:12 PM
juanvaldez
juanvaldez's Avatar
<1% because they are not driven.
Old 05-05-2018, 10:35 PM
UmCanesZ06
UmCanesZ06's Avatar
I've had 4 Z06's and never had a head/valve issue so my percentage is 0
The following 3 users liked this post by UmCanesZ06:
71HO454 (05-07-2018), juanvaldez (05-05-2018), Whiteonrice (10-06-2019)
Old 05-05-2018, 10:38 PM
juanvaldez
juanvaldez's Avatar
I only tore down one LS-7. All intake valve clearances 10 times factory spec.
Old 05-06-2018, 12:44 AM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
A much better/ more relevant question is "how many LS7's have valve guides out of spec.?". From the data we've seen just on this forum alone, an overwhelming percentage do.
Out of spec. valve guides are clearly the number one contributing factor to valve failures.
Now, some people on this forum are gamblers, and they continue to drive their cars knowing full well (or in the case of the "head-in-the-sand" crowd, they don't even bother to check) a critical component is worn past its service limit. They are litterally "playing the odds" that they won't get burned.
One can be just lucky, or lucky and smart.
LTVN68 (05-16-2018)
Old 05-06-2018, 01:07 AM
LV Vette
LV Vette's Avatar
St. Jude Donor '08
Got a question for all the people saying the valve fix is a waste of time. What percentage of S.W.A.T. officers are shot and killed? What percent of S.W.A.T. officers wear bulletproof vests? I realize this is a harsh analogy, but just get the heads fixed and not have to take the chance you will be one of the unfortunate ones.
Old 05-06-2018, 06:22 AM
_BlueZ06_
_BlueZ06_'s Avatar
How you interpret the information is dependent on the person. There have been a number of LS7s with dropped valves considering the low mileage put on most Z06s. As Dan mentioned, many of us have had ours checked and fixed which reduces the number of actual dropped valves. I'd have them checked and then make your decision if the risk is worth it.
LTVN68 (05-16-2018)
Old 05-06-2018, 08:56 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Meh,,, it rarely happens ever, I wouldn't worry about it.. Drive the **** out of that thing!!!
Old 05-06-2018, 10:03 AM
Apocolipse
Apocolipse's Avatar
Received 1,290 Likes on 934 Posts
Did I miss summer and it is back to winter threads??
Old 05-06-2018, 10:50 AM
sam90lx
sam90lx's Avatar
I once thought the hysteria was over blown, had mine checked on my bone stock 2012 with 17899 miles..... 16 out of 16 we’re out of spec.
LTVN68 (05-16-2018)
Old 05-07-2018, 11:50 AM
h2oskiman
h2oskiman's Avatar
Ok here's my problem. I have an 08 z with 37k on it now. I have an extended warranty for 2 more years. I'll never hit the miles in two years. So do I drive it till the warranty is about up .If I check it now and find problems with the valves will the warranty take care of it before something happens. If I have the heads redone by some after market company there goes my warranty.It is completely stock. Blackstone report was good. Just not sure what to do ?
Old 05-07-2018, 12:05 PM
NotreOkc
Support Corvetteforum!
NotreOkc's Avatar
Your warranty is not going to cover preventative maintenance, so drive the hell out of it for the next 2 years then decide if you want to address the heads for peace of mind. I never even checked mine on my Z06 in 4 years and never had an issue.
Old 05-07-2018, 12:59 PM
moose.b3
moose.b3's Avatar
Wrong! If your heads are out of spec your warranty will pay to replace your heads. GMPP has replaced 2 sets of my heads because they were out of spec. The second set is being replaced with AHP reworked heads now, payed for by GMPP. I really can't believe the bad advice that is still being given after all the heads that have been measured out of spec. Let alone all the engines that have holes in their blocks from broken valves.
LTVN68 (05-16-2018)
Old 05-07-2018, 01:07 PM
sam90lx
sam90lx's Avatar
Same here, GMPP is covering my AHP head replacement as well.
To what percent of c6 ls7s drop valves?
Old 05-07-2018, 01:37 PM
NVNO1
NVNO1's Avatar
Well my Z06 is in my garage with a destroyed engine as we speak. I'm having AHP build me a new engine as my Z06 was out of warranty. It's an 09 but only has 5k miles on it.
That said I also have a 2015 Z/28. It is still under warranty until June. My question is how do I get American Heritage Performance reworked heads on it? Do I have to take the car to the dealer to have wiggle test done? I so cringe at the thought of having the dealer within 100 feet of my car. Basically how did you go about having AHPs heads on your car using the GM warranty?
LTVN68 (05-16-2018)
Old 05-07-2018, 02:01 PM
moose.b3
moose.b3's Avatar
I took my Z to a Chevy dealer that is very familiar with the valve guide problem. I had them do the wiggle test to give me an indication of whether or not the valves seemed to be out of spec. If the valves seemed to be in spec, I was going to have to pay for the wiggle test. But both times I had the test done, the valves were deemed to be out of spec. The first time was 5 years ago and the heads were replaced with new GM heads that lasted 23,000 miles. A lot has been learned in the last 5 years and GMPP now works with AHP so we can get their fixed heads. You're not that far from AHP, call them.
Old 05-07-2018, 02:08 PM
NotreOkc
NotreOkc's Avatar
Then I stand corrected on the GMPP warranty. I know several buddies with Z06's that were not covered. So it is not completely bad advice.
All the engines that have holes in the blocks? All ~1% of them?
Quick Reply: what percent of c6 ls7s drop valves?
