[Z06] Installed Vette Air now car cuts in and out on hwy????
So I installed the Vette Air on my 08 H/C/I ZO6. It has a Halltech CAI with the shield around the filter. So when I drive the car down the highway and I get above 60 miles an hour the car feels like it’s cutting in and out or it jerks a little. What would cause this? Do I need to re-tune it for the extra air or is it creating turbulence with the shield around the filter? And should I just remove the shield. I know the shield keeps the hot air from coming in from the filter but I also just installed a LG vented hood so now it could release the heat from there. Thank you for any help.
It's called "surging", caused by turbulence at the MAF.
MD and I tried installing a honeycomb screen in the airflow path (similar to what GM used to put on the LS1 MAFs). He was trying to solve a more serious cam-based reversion issue, I was trying to solve the problem you have here (intake with airflow directly from the front of the car).
For me, it was "successful" in that it did reduce it somewhat (and I saw a more stable pattern in the MAF logging), enough that I forget about it until a question like this comes up. Your mileage may vary..
Same issues I had by doing the propped shroud mod...... turbulent air affecting the MAF, which is more prevalent in the MAF forward design of the later Halltech intakes.
This happens only at light throttle, not WOT.
I heard that if you placed a deflector at the opening of the Vette Air at the airfilter, it solves this problem.
Note that Vararam intakes have this same blast of ramair coming into the filter, but the MAF is located at or near the original location as stock....up near the throttle body and away from the filter.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,123 Likes
I talked to Jim Hall on the phone about this exact subject before I bought my 107R intake. He emphatically told me to dump the Vette Air and blank the hole before installing his intake. He went on to say that the turbulence caused by it will cause problems with the MAF.
Received 1,679 Likes
So my question is what is better. Do I get rid of the vette air and block it and put the shield back on or do I keep the vette air and just remove the shield? I was even thinking what about keeping the vette air and cutting partial of the side of the shield to release some of the pressure so it would not cause turbulence and I could keep both? Like a said I do roll racing
Use some double sided tape from 3M to attach it so it could be removable.
I wanted to make sure you weren't installing something else on the filter or in the filter area. I find it odd that you are seeing this problem with the BeeHive installed, but not with it removed. Seems to me that air flow from the Vette Air scoop would increase with the BeeHive removed. But if you are feeling it, it's happening......
I installed the VetteAir scoop a year ago, and I have the BeeHive and the MF108. Dan mentioned earlier that I installed a honeycomb, which is correct. MAF Hz is pretty solid, so the Honeycomb must be helping. You might consider installing one yourself. You will need to recalibrate the MAF if do though.
That's interesting because I also have the Halltech with the beehive shroud and my car in 5th/6th seems to "jerk" on occasion.I just did a 4-5 hour trip each way and experienced this.I hope the honeycomb fixes the issue.
Make sense ?
