C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Ls7 blower options
Old 09-14-2018, 03:04 AM
Mikec318
Mikec318's Avatar
Default Ls7 blower options
what’s the best blower kit for a 2008 zo6 stock bottom end Heads are fixed and milled
Old 09-14-2018, 11:02 AM
ss2z06
ss2z06's Avatar
Ls7’s don’t take boost for long. I don’t suggest it. If you still decide to go that route look at a kit from either A and A corvette or ecs. Both make great kits.
Old 09-14-2018, 11:06 AM
Patriot Six
Patriot Six's Avatar
A&A or ECS. Properly set up and tuned for 700rwhp or less and you’ll be fine on stock bottom end unless you beat on it everyday at the track. The milled heads could pose a problem.
Old 09-14-2018, 12:12 PM
meanjoe
Support Corvetteforum!
meanjoe's Avatar
LS7 is just not a good candidate for boost. Not at all what it was designed for.
Old 09-14-2018, 12:13 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
What patriot said.
ECS or A&A
Milled heads could be an issue and you probably want to swap some unmilled fixed heads on, or you may be stuck running meth/e85 to overcome the milling. Target ~700rwhp at most, and keep it on safe side. Should only take 4-6psi to get there.
Old 09-14-2018, 03:47 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
Two problem with blowers and LS7s with stock short blocks:
1) Compression. It's so high that you're going to live with either a very low level of boost, lots of KR and the coolant heat that goes with that or 100-oct. unleaded.
2) Cylinder walls which flex. The reason GM never put a blower in the LS7 is it's cylinder walls are too thin for boosted applications. The result is the bore walls flex which reduces durability and can create an oil control issue.
The magnitude of these problems will depend on how much you beat on that motor once you install the blower.
Old 09-14-2018, 04:37 PM
Mikec318
Mikec318's Avatar
Thanks guys. I plan on running meth/e85. Also not now but in the future I do plan building the bottom end. I’m undecided about the thing still. As I do have a full nitrous outlet plate kit set sitting in my garage
Old 09-14-2018, 05:24 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Hate to say it, but if you do decide to go FI...I would plan to address bottom end sooner rather than later. Depending on mileage, you could get a decent chunk of change for an LS7 short-block (or long-block) in good working order. Take that money and put it towards a new sleeved block. If you do it after you pop a cylinder, that short-block is mostly likely only good as scrap metal or a coffee table.
Old 09-14-2018, 05:40 PM
Mikec318
Mikec318's Avatar
definitely food for thought
Old 09-14-2018, 06:26 PM
MTPZ06
MTPZ06's Avatar
Short block in good condition would probably bring ~$4500, and a long block ~$7000
Old 09-15-2018, 04:39 PM
trogdor
trogdor's Avatar
talk to an engine builder the forum has several sponsers... tell them your goals and get some ideas from them... maybe they can take your motor on consignment or something.... a forged 402 and boost and you will be going to plaid
Old 09-15-2018, 05:59 PM
Unreal
Unreal's Avatar
Unless prices went up, I was able to get $3500 for my short block.
Old 09-16-2018, 09:37 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
It is NOT required to get a built motor to go FI for your C6 Z06. I have a ton of customers who have superchargers on bone stock cars.
What is your HP goals?
What do you do with the car?
Do you need a kit that is smog legal?
Let me know the answers to the questions above and I would be happy to help you
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Old 09-17-2018, 06:44 AM
Mikec318
Mikec318's Avatar
I’d like to be mid 700 to low 800 hp
mainly street driving some 1/4 mile and roll racing
Old 09-17-2018, 05:27 PM
SocalChvy
SocalChvy's Avatar
In your experience, which system is the most reliable?
Old 09-25-2018, 06:10 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Meth, mild, cam, and A&A or ECS kit would get you where you want.
Old 09-25-2018, 06:45 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
All the kits are very reliable... we sell a bunch of Procharger, A&A, and ECS. Since you live in CA I would HIGHLY recommend the A&A kit since it is CARB legal
To Ls7 blower options
Quick Reply: Ls7 blower options
