How to test Nick Williams Tb??
That's what mine was doing when the TPS went bad. The crappy thing is that you cannot replace the throttle position sensor on that TB.
There's no tuning to the TB, the pcm has to be tuned for the increased airflow and that's a different error, unexpected airflow code.
Your error comes at WOT which is the TPS misreading throttle position, it's got a bad tps.
also you say the TPS in the thorttel body is crap or broken !?
also if I tune the TB with Hp Tuners with my friend the failure comes again??
thanks for your help man
Its most likely the TPS, works fine until WOT or above 80% then it craps out and the engine/pcm goes into reduced power mode with rpms hanging around 1900-2100rpm. Throttle becomes unresponsive to input
hy_bmw_freak (11-05-2018)
How can i Swap this ?? what you mean with the Gold bladed TB do you mean Throttle flap ? Where can i Find that ?
What is with the Stock GM Thorttle body can i swap the TPS from stock Body to the 102 mm Thorttle body ?
The Car is Ls7 2006 Z06
That didnt work when I tried it on my LS2 TB, it came the f apart and the TPS was bonded to the TB. Mine was an ACDelco TB though, made in China so that may have been the problem
Also my original Gm throttle body with silver plate goes from 25-85 ~percent and the another one goes from 25-82 precnet
after this I open the new 102mm throttle body and limited the way from 25 percent to 70 percent but i have the same issues if I give full thorttle to the pedal failure comes again.
P1516
I think maybe the problem is full thorttle is not 85 percent on the throttle body and because of it the failure comes if the ecu need the 85 percent not the 82 percent??
P1516
I think i know the Problem i have Stock one ls7 Silver blade throttle body and after 2009 ls3 ls7 has Gold blade throttle body and the 102 tb goes the same direction opening and closing like that the lade models tb
also I think without any tune its not possible to run a thorttle body with another opening direction.
Otherwise if I'm wrong
jayyyw (11-13-2018)
#33
