[Z06] How to remove/install brake cooling inserts
Hi all,
Does anyone know how these inserts come out? Do I just pull them out or is it held on by some clips that can break?
Can’t remember for sure but I think they just snap into a separate plastic piece that sandwiches the fender between them.
jorge18 (11-19-2018)
Pretty much. You need to remove your fender liner, then it is a two piece deal. The retainer which goes inside the fender needs to be compressed (or expanded, I don't remember) which will release the vent which is on the outside of the fender. It's all 10 year old GM plastic so you want to be careful with it but the first side took me about 20 mins to figure out, the second I was done in like 5 including removing the tire. Hard to describe but once you see how it goes together, it is easy.
Do you think there's any way to do this without taking the tire off?
I used a hack saw blade and cut the middle plastic piece then snapped it off. After that you can squeeze the duct which releases clips and pull out.
Look at this thread:
https://www.corvetteforum.com/forums...tall-help.html
EDIT - the above is for the rear brake intake vent not the front, sorry.
What I found for the front fender vent, Post 11 in https://www.corvetteforum.com/forums...post1573086317:
Quote:
Originally Posted by bluemagoo In the service manual it's referred to as "Front Fender Ornament".
Raise and support vehicle.
Remove the front wheel and tire.
Remove the rear portion of the front wheelhouse liner.
Remove the fender ornament from the inside of the wheelhouse opening by releasing the three integral tabs on the inboard side of the front fender ornament.
Hope that helps get you started.
