C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
No, if you remove the abs module bracket it gives you some more room and flexibility.
I did it this way; removed the bracket and slid the entire assembly forward. I also removed the PS pump although I've read where this isn't necessary. It wasn't difficult, and freed up some space, so in the end it was worth it.
