C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
AH and multiple sets of tires with TPMS
Old 05-16-2019, 12:41 PM
GndHog
GndHog's Avatar
Default AH and multiple sets of tires with TPMS
Ok - checked almost all the threads here and not found a good solution. 2013 ZR1
have coil overs with shock deletes - no issue can still get to race mode with no other errors - provided a TPMS sensors working.
when swapping out street tires for race slicks - my TPMS learn tool is about 25% successful in getting new wheels learned - when the fail to learn correctly - of course service handling message comes on and race mode can’t be selected anymore
so AH kicks in and #&!!$$ me on the corners by pushing brakes....no good
so to solve that - pull steering wheel sensor but service handling message comes on again and speed limited to 158 mph - no good at COTA and other tracks with long straights.
would like to run with steering sensor pulled (no need to worry about TPMS message) but want to get rid of the 158 mph limit.
is there a way to do this?
can a Tech 2 turn on/off (disable) certain F55 codes?
Old 05-16-2019, 12:52 PM
ttx350z
ttx350z's Avatar
What about the LG track box. Eliminates tpms and you can connect your steering wheel sensor.
https://www.lgmotorsports.com/lg-mot...liminator.html
Old 05-16-2019, 01:35 PM
GndHog
GndHog's Avatar
Aware of the LG track box - want to be able to use TPMS on race wheels if can get learn tool to work 100% of time....valuable data to have
more asking what one can and cannot adjust on the F55 module
Old 05-16-2019, 02:52 PM
ttx350z
ttx350z's Avatar
Gotcha.
TPMS and reset tool battery new?
My $16 tool from amazon works 100% of the time and only takes seconds.
Old 05-16-2019, 03:43 PM
Sox-Fan
Sox-Fan's Avatar
i have
one of these one of these
and it has never not worked. I change my tires two or more times a day on a track or autocross weekend. Never had an issue with it not getting the new wheels and tires learned.
Old 05-16-2019, 04:13 PM
GndHog
GndHog's Avatar
TPMS all new, have same $16 tool from amazon
VXDAS EL-50448
maybe put new battery in it - no low batt indication
Old 05-16-2019, 07:45 PM
GndHog
GndHog's Avatar
Went by local shop here that had a Tech 2 - even with all TPMS sensors working fine / still got service handling message and 158 mph limit imposed - cleared codes on F55 with tech 2 and still got error - could set in race mode and see that AH was off - all TPMS sensors working but 158 mph limit was there.....
Old 05-17-2019, 12:10 AM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Just do what I did.. Abandon all that BS and run a TPMS eliminator. This is superior to the LG solution (NO error codes set) and way cheaper, and the right way to do it (emulates the wireless signal from TPMS).
Enjoy - https://www.ebay.com/itm/TPMS-Delete...-/162844798447
Old 05-18-2019, 03:42 AM
GndHog
GndHog's Avatar
Again would like to keep using the TPMS if possible and NOT have car take a dump if one sensor comes in/out for few minutes.....having increasing tire pressure over time is good data to have on the track.....
there’s got to be a way to disable AH all the time and keep TC and ABS fully functional.....without getting the 158 mph imposed....pulling steering position sensor plug is only 1/2 the correct solution....
To AH and multiple sets of tires with TPMS
Quick Reply: AH and multiple sets of tires with TPMS
