C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Heads Fix and Custom Camshaft
Old 09-20-2023, 01:55 PM
DGCorvetteSarasota
DGCorvetteSarasota's Avatar
Default Heads Fix and Custom Camshaft
What are you thoughts on the build spec below? Price?
Custom camshaft, Hardened Pushrods, GM LS7 Timing Chain, GM Water Pump Gaskets, GM Crank Pulley Bolt, GM Front Crank Pulley Seal, Mobil 1 Oil and Filter Change and NGK Spark Plugs
CNC’d Ported and Polished LS7 Cylinder Heads w/CHE Precision Bronze LS Valve Guides, .660 Dual Valve Spring Kit, GM MLS LS7 Cylinder Head Gaskets, GM LS7 Lifters, and GM Head Bolts
Old 09-20-2023, 02:39 PM
furious427
furious427's Avatar
Sounds good, who is doing the heads and what cam are you going with?
Old 09-20-2023, 06:00 PM
JMB
JMB's Avatar
Use a Cometic 0.040" MLS, much better quench than the OEM 0.051" and a slight bump in compression for a pinch more power!
Old 09-20-2023, 07:24 PM
KennyPowers
KennyPowers's Avatar
Why use GM head bolts? ARP right..
Also I'd make sure the push rods are sized when you set preload.. ALWAYS good to check prelaod..
To Heads Fix and Custom Camshaft
Quick Reply: [Z06] Heads Fix and Custom Camshaft
