Issue with memory seats/mirrors
So its not a huge deal, but its inconvenient. Ever since I fired the car up this year the seats and mirrors all return to the I'm assuming default position. The seat all the way back and mirrors adjusted for that position. The car has never done this before. The 1 & 2 memory positions still work, but as soon as the car turns off the seat and mirrors revert.
I did some searching on the forums and the closest thing I could find to the issue was a connector in the seats being loose. Before digging around for that under the seat anyone else have any suggestions? I'm honestly assuming this is a dumb question and I'll feel dumb once I hear the explanation lol.
Are you saying this happens when you start the car or when you turn it off? It should only do that when you turn off the car and set the emergency brake (which is the easy exit mode).
I would first try disconnecting the battery for about a minute or so and then reconnecting it to reset things (you will then have to reindex the windows). You could also try resetting the 1&2 memory settings.
Is there a way to disable easy exit mode? I hadn't heard of that, but that sounds sort of similar. To answer the next part of the question it does it no matter what. It does it when I turn the car off, but if I hit the seat button on the side it will stop but then when I get back into the car and turn on even accessory mode it just does it anyways then
Well time to take it into the dealership with my tail between my legs haha. I tried changing the easy exit mode and other memory functions in the DIC according to the manual and it still returns seats and mirrors to a fixed position. I'm wondering if it is like the issue I found when I searched this on the forum earlier and just a bad connection from a sensor. At least I did figure out with the manual how to reset my clock so thats displaying the correct time again haha
So you didn't have to reindex your windows after disconnecting the battery? Every time I disconnect the battery I have to reindex the windows (so they go all the way back up when I close the door), along with resetting the time.
Received 9,002 Likes
