C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Problems with STS kit
Old Nov 4, 2006 | 07:58 PM
dstage's Avatar
dstage
Default Problems with STS kit
I got a STS kit on my C6. The problem that I am having is that at 7lbs of boost the car does great, but when I switch to high boost which is 10 lbs, at about 120 mph the alarm goes off telling me that no oil is getting to the turbos.
Do I need a pump upgrade, or just do a seperate oiling system in the back of the car for the turbos?
Old Nov 5, 2006 | 01:46 AM
Brabus2's Avatar
Brabus2
Give STS a call to help troubleshoot your problem, good luck.
Old Nov 5, 2006 | 08:40 AM
EuroRod's Avatar
EuroRod
Honestly, that oil pump system to lubricate the turbos is what turned me off from buying the STS kit. If it fails, you're quickly buying two new turbo's.
Old Nov 5, 2006 | 01:03 PM
c6tt's Avatar
c6tt
3rd Gear
You most likely just need to slightly adjust the sensitivity of the oil pressure alarm. They are sometimes just a little too sensitive when you run the higher boost levels. Find the Alen screw, under the rubber cap, on the sensor and turn it clockwise 1/2 turn.
Old Nov 5, 2006 | 07:23 PM
runutzzzzz's Avatar
runutzzzzz
10LBS? Wow, what's the HP?
Old Nov 5, 2006 | 07:45 PM
dstage's Avatar
dstage
made 578 rear
Old Nov 6, 2006 | 01:15 AM
Brabus2's Avatar
Brabus2
made 578 rear
...Are you running the STS meth kit also?
Old Nov 9, 2006 | 02:00 AM
New Era Performance's Avatar
0New Era Performance
Former Vendor
10 psi is abput where you will need the oil pump upgrade , also , 578 at 10 psi level on a 6-speed is kind of low as I have gotten 597 out of a stock C5 at 7 psi . But maybe it is detuned for safety (which it probably should be on the stock bottom end) ?
Old Nov 10, 2006 | 12:00 AM
Nmbr1GMfan's Avatar
Nmbr1GMfan
Also, not all dynos are created equal.
Old Nov 16, 2006 | 04:39 PM
RDunn's Avatar
RDunn
Old Nov 29, 2006 | 10:15 PM
dstage's Avatar
dstage
Originally Posted by RDunn
No, But its got a bad *** inercooler. Yes it is stock bottom end. Also I have LG headers, so I am actually losing power.. I know it sounds crazy, but the headers are losing heat unlike thew stock headers. I am also doing a seperate oiling system for the turbos. Kind of like a fuel cell in the truck dedicated for the turbos
Old Nov 29, 2006 | 10:21 PM
AP's Avatar
AP
Listening ...
Old Nov 29, 2006 | 10:33 PM
dstage's Avatar
dstage
This will ensure that the turbos are getting oil quick enough at higher boost levels. Also I am doing a forged bottom end LSx base motor. I plan on running 20 psi with a 35 shot of nos also a turbo upgrade to a GT35R
Old Nov 29, 2006 | 10:38 PM
dstage's Avatar
dstage
To be honest with you, There are a few things that I am unhappy about with the STS kit..
The oil system.
No base tune available from STS at the time of install.
Had a problem with baffle in the 06 vette. Appartly it is differnt in the 05. I went sent 3 pumps back to STS and told them they werent working properly. On the 4th time they told me to make the baffle larger with a drill bit. This solved it.. Only after oil passed through my turbos 3 times.
Old Dec 4, 2006 | 10:33 AM
turbo_tom's Avatar
turbo_tom
To Problems with STS kit
