C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Vette knocking
Old Feb 3, 2007 | 09:55 PM
dstage's Avatar
dstage
Default Vette knocking
At low boost 7psi car does great. At 10 psi car knocks at full boost and pulls 4 deg timing. Air fuel is between 11.3 and 11.5 but when car knocks in 4th gear at 5ooo rpm air fuel jumps to 13.5. I really dont wont to run high octance gas all the time cause $$$, I think that would solve it, currently using 93 octane. Prob need to do a forged motor, but I'd like to see what the LS2 is capable of on stock bottom end. Guess I have met its limitations. Any advice???
Old Feb 3, 2007 | 10:47 PM
Zteve's Avatar
Zteve
A forged motor is going to do anything if you're leaning out. You either have a hole in your tuning or you've maxed out the injectors and or fuel pump. Fix that and you're back in business.
Old Feb 4, 2007 | 01:20 AM
dstage's Avatar
dstage
Yea, Thanks for advice. Think fuel is maxed. Gona try APS fuel pumps
To Vette knocking
