C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Running Lean
Old Mar 17, 2007 | 02:40 AM
GreggHammer's Avatar
GreggHammer
Default Running Lean
I'm running lean on my Procharged (upgraded injectors) '06 coupe, even with fresh plugs. Anyone else had this problem, if so, how did you take care of it without sending the ECM sent away to be tweaked?
Old Mar 17, 2007 | 07:52 AM
booztedz33tt's Avatar
booztedz33tt
This should help, i saw a procharger that was running lean up top, they added this and fixed it
http://www.kennebell.net/accessories...boostapump.htm
Old Mar 17, 2007 | 07:54 AM
EPP's Avatar
0EPP
Former Vendor
We have had the same problem crop up.
http://www.exoticperformanceplus.com...Car.php?car=30
We added a boost a pump to the car in the link above, which took care of the problem. Some of these cars are okay without it, and other ones need it. I always recommend checking the air/fuel ratio, your case is a perfect example, as you found out. Bob
Old Mar 17, 2007 | 05:31 PM
GreggHammer
Can I install this in my garage?
To Running Lean
