C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
i ve got marbles
Old May 9, 2007 | 04:51 PM
deuce02's Avatar
deuce02
Default i ve got marbles
marbles in a can sound at idle common?
and only 6oz of oil?
Old May 9, 2007 | 06:45 PM
Pio's Avatar
Pio
Not good. Marbles in a can sounds like detonation. Detonation = bad!
Old May 10, 2007 | 06:19 AM
EPP's Avatar
0EPP
Former Vendor
I assume you are talking about having an ATI ProCharger. ATI ProChargers use straight cut gears that need to be broken in. This break in period takes about 500 miles and the noise normally quits down considerably. Bob
Old May 10, 2007 | 06:39 AM
Jerseyboy's Avatar
Jerseyboy
Yup, it's a characteristic of the Procharger. It's due to the straight cut gears and lash (excessive IMO) in the gear mesh. You might be able to bump up your idle speed a little to quiet it down some but you will never get away from it.
Jersey
Old May 10, 2007 | 09:15 AM
LJo's Avatar
0LJo
Former Vendor
Jersey
In your opinion, how much lash should there be?
Old May 10, 2007 | 09:27 PM
excessive81's Avatar
excessive81
that sound will go down. then you will get the wonderful whine. mine totaly changed once i did first oil change
To i ve got marbles
