Procharger D1SC - LS2 Engine BLOWN UP!
I bought a Procharger D1SC (sn: 28172) type supercharger for my CHEVROLET CORVETTE CONVERTIBLE 6 speed manual (VIN number: 1G1YY34UX55132048), in August 2006. The car has run till now totally 2.200 mile, from which I drove 930 mile with the Procharger. Each time I used the best quality octane 100 fuel used in Europe, plus NGK TR6 plugs are mounted in the car.
For your information: in Europe the purchase of the Procharger is not easy neither cheap, for this reason we were totally careful of mounting and using it in the car.
Last week, after a 50-km highway-use, I heard a "knocking" from the motor before stopping the car. I took it to the service, where the mechanic astonishingly realized that the motor was burnt down, the valves were also burnt, the sparkplug was melted down, one of the pistons head was tore off, another one was sintered, which finally caused the "knocking" sound.
There were already two oil-changes in the Corvette inspite of the moderately few-miles-running, and I already changed the oil also in the Procharger, according to the instructions.
Please give me advice what kind of new engine I shall purchase, because I do not trust repairing the existing one.
I wonder whether the guarantee of the Procharger covers such cases, but this special incident was shocking to me. I want to mention that the Procharger unit is unharmed.
Please check the pictures at ftp://ftp.acomp.hu/pub/Vette/
Waiting for Your suggestions.
Best Regards,
Gabor Keresztes
[IMG]ftp://ftp.acomp.hu/pub/Vette/[/IMG]
but if u don't mind me asking few q
what level of boost ur running?
what tune you used ..i mean did u get the procharger handheld or u send ur PCM to be prorgrammed..?
please I'm just trying to figure out what went wrong coz it the 1st time i heard such thing and a lot of people here are running 1DSC unit in their car it could be wrong A/F ratio
and for the new engine u can always go bigger CC now and there are a lot of forum vendor are willing to help...
Purchase an engine built with forged rods and pistons with a compression ratio of 9.0/1 to 9.5/1. Bob
Until this time, the Procharger D1SC was excellent. The car has run strong and without any problem.
Has anyone an idea how to get a new complete engine, which fits well with the Procharger D1SC?
On your future build consider adding fuel pressure and A/F (air fuel ratio) gauges to warn you if problems are about to arise. If you can’t do both then at least A/F is a must.
As far as engine builders there are lots of good ones to choose from. I would select very carefully as it is being shipped overseas.
Double check your PCV system because as mentioned above you do have allot of oil buildup present.
Oh, for a good mail order tune check with Charlie @ RPM Motors (a forum vendor).
Good Luck,
Mike
How does everyone else run <10psi on these? Restrictor plates?
12 months from now I have a forged motor
Now I need 12-14 psi
Cost to upgrade from a P1 to D1 = 1/3 the cost of the kit
This is the reason some want to run a larger setup, that and if you run a restrictor plate you push the power more under the curve and it comes on earlier...
Sorry for your issues, but now you can look forward to forging the bottom end and making big power.
- www.fastchip.com makes a standard tuning for D1SC. I do not asked them to made it stronger than normal.
- In Europe the "Normal" gasoline is 95 Ocante, "Super" gasoline is 98 Octane and If You want a really good You can buy 100 Octane gasoline also. I always bought 100 Octane.
DO YOU KNOW ANYONE WHO CAN BUILD ME A LOW COMPRESSION LONG BLOCK FOR THE D1SC?
Thanks for Your help!
