C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Vortech BOV replacement?
Old Nov 23, 2007 | 10:13 PM
ayousef's Avatar
ayousef
Default Vortech BOV replacement?
Hi there guyz, Im thinking of replacing my crappy Vortech BOV for something better, and hopefully something that sounds like a BOV not a silent bov like the standard one that came with my Vortech. Which BOV's do you recommend, and will they produce ENOUGH sound to be noticed by people even with my extremely low boost application, sub 5PSI on a C6 Z06?
Also how much tweaking do they need, I know they are adjustable but how adjustable are they, im just hoping something would work out to support my low boost application, and not cause any compressor surge.
ideas?
Old Nov 24, 2007 | 03:28 PM
ayousef's Avatar
ayousef
thanks for being SOOO helpful >.<
Old Nov 24, 2007 | 04:25 PM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
http://www.procharger.com/store/inde...od&productId=4
I am putting this one on mine. I've heard it on a procharged Z06 and it is NASTY!! He has 10lbs. of boost on his. I am picking my car up on Tuesday and will post some videos of how it sounds. You can also look at the Tial 50mm. Take a look at this link.
http://forums.corvetteforum.com/show...highlight=tial
John
Old Nov 24, 2007 | 04:31 PM
ayousef's Avatar
ayousef
John
I was thinking of an HKS or a Greddy BOV, however I don't know if they would work with my set-up especially the low-boost issue. What do you think, this BOV in the video is too quite for me, I like the sound of the Greddy and the HKS the most. Also I am not sure if I would ever hear a BOV dumping boost with such low boost.
Old Nov 24, 2007 | 04:37 PM
thomas walters's Avatar
thomas walters
Heard good things about the HKS SSQ BOV, although I have no personal expience with this brand.
http://www.raceinspired.com/pc-691-2...-all-cars.aspx
Old Nov 24, 2007 | 04:43 PM
ayousef's Avatar
ayousef
now do you have any idea if it would work with sub 5psi boost applications?
Old Nov 24, 2007 | 07:22 PM
thomas walters
That question is over my head, I am sorry to say.
Old Nov 24, 2007 | 08:55 PM
C6dude's Avatar
C6dude
ayousef,
.... The HKS SSQ BOV will work for you with the correct flange.
Even at low boost and they don't leak. I had it in my car before I went to the larger 52mm Turbosmat unit.
You will definitely hear the whistle between gears.
Hear is a video I took when I had it on my car.
The mic is under the hood so you can hear it better. Try to block out the backround noises.
http://www.youtube.com/watch?v=KqLbrEPtNyw
.Perry
Old Dec 5, 2007 | 09:45 AM
dcorn's Avatar
dcorn
If you are running the bypass valve recirculating back into the intake, you will be hard pressed to hear much of anything. I recently ran a HKS SSQV on my vortech mustang making about 10 psi and for some reason, I kept getting a vacuum leak. I'm not sure what it was, I think I've heard of issues with the 2nd gen SSQV. If you have the stock style bosch valve that hooks up to 2 1" hoses, try a greddy or TurboXS bypass that is made for a VW/Audi.
Old Dec 5, 2007 | 10:55 AM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Do you know if there would be any tuning changes or requirements by just changing out the Bosch valve with a Greddy etc, or is it just a simple valve change out?
Old Dec 5, 2007 | 02:22 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Simple change out for your application Dave.
Old Dec 5, 2007 | 02:42 PM
DOUG @ ECS's Avatar
DOUG @ ECS
John
I have the ATI unit on my vert and it sounds like a jet coming down the street! I personally like it, but your not hiding your F/I kit, that's for sure.
The Tail 50mm works great also, with the 7lb spring it has more of a whoosh sound between shifts and the ten lb spring has more of a che-che-che-che-che sound. It's all personal preference which is why we include a more stealthy unit for our SC kit, then it can be personalised from there if so desired.
Old Dec 5, 2007 | 02:52 PM
06.Z51.MontRed.Vert
Thanks Doug. Do you know if the unit with the 7lb spring is quieter than the Bosch during normal cruising, but louder between shifts? I wouldnt mind having the wooosh sound between shifts, but I would prefer if it was a little quieter during cruise (less of an air compressor sound -"che che che che che").
Old Dec 5, 2007 | 08:32 PM
vavroom's Avatar
vavroom
3rd Gear
The vortech mini race is a good unit.. sounds much better than the fluttering small type
Old Oct 9, 2011 | 09:53 PM
Oil Rig Pilot's Avatar
Oil Rig Pilot
can anyone post the differences in a video ? i would like my Vortech to sounds more aggressive also..
To Vortech BOV replacement?
