C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
boost and headers
Old Dec 9, 2007 | 03:40 PM
ayousef's Avatar
ayousef
Default boost and headers
well just installed the boost gauge recently, with catless kooks, and a free flowing exhaust, my boost dropped from the Vortech advertised 6.5PSI to sub 5, am guessing about 4.9PSI @ max revs (7000 RPM) does this sound right?
Old Dec 9, 2007 | 03:50 PM
George Scott's Avatar
George Scott
What happens here is the s/c with the pulley it came with stock is design to support advertised power/boost on a stock engine. Once you improve the efficently the exhaust back pressure drops and the boost falls off. To make the most of your upgrade you will need to speed up the blower.
Old Dec 9, 2007 | 04:01 PM
C6dude's Avatar
C6dude
Yes, It is normal.
The increased flow with the headers is what is causing the drop to 5psi.
You are making the same power with less boost.
Time for a smaller supercharger pulley to take advantage of your headers and bring your boost back up to 6.5psi.
Perry
Old Dec 9, 2007 | 09:25 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Old Dec 9, 2007 | 09:26 PM
1bdasvt's Avatar
1bdasvt
Same happened to Mine with My Maggie and headers!!
Take care Al!!
Old Dec 10, 2007 | 12:37 AM
ayousef's Avatar
ayousef
thanks alot for the explanation, I guess thats what I need to do
Originally Posted by C6dude
Yes, It is normal.
Perry
Hey Perry, problem is there isnt any pulley smaller than 4.5 that would yeild a 1-1.5 increase in boost, the next pulley on the line is a 3.8 which is way small
Im not sure if a procharger pulley would work, guesses?
Take care Al!!
thanks alot man
Old Dec 11, 2007 | 09:56 PM
RICKEY BOBBY's Avatar
RICKEY BOBBY
thanks alot man
vortech makes a 4.10 also im getting one myself give them a call
Old Dec 12, 2007 | 03:02 AM
ayousef's Avatar
ayousef
youll run it with the stock engine?
Old Dec 12, 2007 | 10:56 PM
RICKEY BOBBY
with blower cam headers my boost fell off a lot need to spin it up some more cartak is doing work hope to with meth kit and more fuel 675 RWHP the tune is key there modifiying my intercooler and moving my air breather
Old Dec 12, 2007 | 11:12 PM
csun213's Avatar
csun213
Can you PM me once you purchase the 4.10 pulley and install it? Do you need to change the current pulley belt with the smaller 4.10 pulley? By the way, where do you see the information on the 4.10 pulley? On their site, all they have is 3.80 and 4.50 pulley. Thanks
Old Dec 13, 2007 | 12:12 AM
RICKEY BOBBY
I was just wondering because cartek told i would loose boost with headers but make super charger more eficient. so I thought I was to safe to raiseback up to at say 6 1/2 pounds so I called and its a new item dont hold me to it I think belt is with it
Old Dec 13, 2007 | 04:44 AM
ayousef's Avatar
ayousef
man you might be able to make that much power, but the engine wont be able to handle it. I am also thinking of a blower cam, but im woring on fixing the bad surging first, and I instially loved the idea that the car would drive just like stock. I think ill switch to a smaller pulley, fix the tune and call it done.
If I mod the car, ill change the rear-end ratio.
Old Dec 13, 2007 | 05:43 AM
EPP's Avatar
0EPP
Former Vendor
I always recommend checking the air/fuel ratio after any mods that affect boost are done. You're probably okay, but it is better to be safe than sorry. Bob
Old Dec 13, 2007 | 04:00 PM
csun213's Avatar
csun213
Just got off the phone with Vortech and they told me that they don't make a 4.10 pulley and have no plans on making one.
Andy from A&A does have a 4.00 pulley however because he has a different mounting bracket than Vortech, not sure how the belt from A&A would fit.
Old Dec 13, 2007 | 05:44 PM
RICKEY BOBBY
I hope the person I spoke with new what he was talking about he took my credit card info and said it would ship same day. Do you have a Zo6
Old Dec 13, 2007 | 05:47 PM
RICKEY BOBBY
They may not have one for C 6 I have 07 zo6 and they pulled my order My buddie is sponserd by vortech and he hooked me up with his rep. east coast super charger also does custom sizes
Old Dec 13, 2007 | 07:12 PM
csun213's Avatar
csun213
I have a C6. Can you find out if the 4.10 pulley will work for a C6? Thanks
Old Dec 13, 2007 | 08:06 PM
BAADC6's Avatar
BAADC6
They just finished mine. I am having the pulley changed also. My heads/cam/headers barely let the procharger make 5psi. cartek is installing a smaller pulley to up the boost a little.
Old Dec 13, 2007 | 09:04 PM
RICKEY BOBBY
Dave and Julio only did the tune one my car It mad 585 Rwhp and After it had been on the dyno for over an hour in 95 plus heat They are gathering my parts now should in by time there in the new shop Did you do your clutch?
To boost and headers
