C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Traction Issues?
Old Dec 22, 2007 | 09:56 PM
ROADKILL2007's Avatar
ROADKILL2007
Default Traction Issues?
Do you need a wide body conversion and fatter tires to effectively use a Maggie 112 or 122 supercharged corvette? Anyone supercharged with stock c6 tires?
Old Dec 22, 2007 | 10:20 PM
9secz's Avatar
9secz
I ran 315 Nitto555 drag radials on the back of my Maggied C5 and could roast them in first with any serious blip of the throttle. Maybe M/T ET Street Radials would hold if they come in the right size, but my $.02 says nothing holds a Maggied LS motor in first gear on the street.
But I'm really hoping someone will chime in and prove me wrong!
Old Dec 23, 2007 | 01:42 AM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Im running the stock GY Supercars ..... They are fine if you have no use for first , second and most of the time third ....
Old Dec 23, 2007 | 11:57 AM
Stage IT's Avatar
Stage IT
Just get some 17x8s and put some wrinkle wall M/T ET Streets (26x11.50x17s) on there
Old Dec 23, 2007 | 12:24 PM
CHARGED UP's Avatar
CHARGED UP
St. Jude Donor '13-'14-'15-'16
I agree. I have Michelin PS2's 305's on 11 inch rims on back & traction is great in 4th 5th & 6th.
Old Dec 23, 2007 | 12:46 PM
ROADKILL2007
Are you guys for real or just #$$%%%ing with me? what's then purpose then if you can't control that power even with 11 inch rims.
Old Dec 23, 2007 | 01:02 PM
Busa196's Avatar
Busa196
I've got 19x13 inch rims with 345 PS2's and Z06 panels......no traction in 1st, 2nd, and the first half of third. I'm more excited than anyone about the 19" Drag Radial that we're supposed to see in the middle of '08. When that comes out, it's "go time"
Old Dec 23, 2007 | 01:44 PM
9secz's Avatar
9secz
Not flaming, just pointing out a possible misunderstanding in your question. You can control the power, you use the pedal under your right foot. What you can't do is indiscriminately mash that pedal. You need to employ that wonderful control mechanism between your ears to modulate your right foot. If you know how to use the throttle intellegently, there is no such thing as too much power.
Watch this video and try not to smile. It's the Camaro in my sig (now sold).
clicky clicky
Old Dec 24, 2007 | 07:07 PM
Stage IT's Avatar
Stage IT
Just get some 17x8s (C5 Z fronts)and put some wrinkle wall M/T ET Streets (26x11.50x17s) on there
Use this setup people are in the low tens with this wheel and tire combo and the wrinkle wall will give your drivetrain a break too. Stiff sidewalls (DRs) are hard on drivetrains. Use those when racing and just pimp some regular tires for cruising.
Old Dec 24, 2007 | 07:44 PM
BAADC6's Avatar
BAADC6
I have 345's on the back with 4.10's and over 600 rwhp. traction is a problem in 4th gear if your not careful. But more power is always more fun
Old Dec 24, 2007 | 08:23 PM
ChargedC6's Avatar
ChargedC6
im running 18in Z06 replicas with 295 BFG drag radials all day traction is ok in first and no problem in 2nd i hook alllll day unless its wet out side. street tires with a blown C6 is pointless and dangerous in my opinion plus your going to get the same mileage out of the tires you mind as well get traction while your at it.
Old Dec 24, 2007 | 09:58 PM
BAADC6's Avatar
BAADC6
I do have drag radials , but for street use I keep the 345 run flats on. I drive the car too far to get stuck with a flat. I will put 6000 miles on it this spring (in 2 weeks) driving across country to Spring Mountain. I'm going to get some 17" rims with MT ET streets for the strip this spring.
Merry Christmas
Old Dec 25, 2007 | 01:06 AM
ChargedC6's Avatar
ChargedC6
Merry Christmas
i got tired of gettin sideways on the street so i gave up on street tires. if anything ill switch to MT streets myself. i have always ran drag radials on my cars and have yet to get a flat.
Be safe have a good christmas!
Old Dec 26, 2007 | 10:36 PM
DSOMC6's Avatar
DSOMC6
I've been running a stock 185 runflat and have had the back end step out pretty seriously on a 2nd-3rd shift (more than once) even with t/c and active handling on! As mentioned above, throttle modulation is about all you can do to combat traction issues without swapping for stickyer tires.
My rear runflats are about shot and I'm hoping for a seriously sticky
19" tire to come on the market soon or I'm gonna have to purchase
18" rims for rear.
Old Dec 27, 2007 | 09:37 AM
FloydSummerOf68's Avatar
FloydSummerOf68
For use on the street consider a MT ET street RADIAL, it is a lot more forgiving on the street than the ET street...it also hooks a lot better than the BFG drag radials.
You will get about half the life out of them though compared to the BFG...but my god do they hook up.
I only had 255s on my firebird and was cutting 1.5s
Old Dec 27, 2007 | 01:43 PM
ChargedC6's Avatar
ChargedC6
thats good to know! i dont really care about the milleage i go through tires about every 2 months. as long as im hooking i dont car. luckily i got friends who run tire shops! ha. but yeah i will definitl me using the ET radials a friend of mine ran them and loved those tires!
Old Jan 1, 2008 | 01:41 PM
bub's Avatar
bub
My GY Supercars remain the "fusible link" in the system helping to avoid any serious upstream drivetrain issues....
Agreed, all control is up to your right foot, plus TC/AH.
Old Jan 1, 2008 | 06:33 PM
07MontRedcp's Avatar
07MontRedcp
During the hot summers in the Phoenix area I find 2nd thru 6th gear to be fine with Michelin Pilot 345s on the rears.
BJK
Old Jan 1, 2008 | 09:13 PM
Gene Gorman's Avatar
Gene Gorman
Traction what is it? I have 345 PS2s on 13" wheels and it will now hook up in 4th gear.
To Traction Issues?
