C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Calling all Maggie Owners
Old Jan 26, 2008 | 12:53 PM
jleonhar's Avatar
jleonhar
Default Calling all Maggie Owners
Tried to cut down the engine covers and am having issues , please post pictures of your successes with tips and tricks or post an alternative solution please.
Thanks for the support in advance.
Old Jan 26, 2008 | 05:23 PM
vettl83's Avatar
vettl83
Lingenfelter has em and so does Callaway. The Lingenfelter ones can be had color matching and the Callaway ones you have to paint. They are both expensive 500.00 + smackers by the time the smoke clears. Far as I know they are the only ones that have em made to fit the Maggie. I bit the bullet and ordered the Lingenfelter ones in A/O.
Old Jan 26, 2008 | 07:33 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
,I did the same!!
Old Jan 27, 2008 | 11:29 AM
Bushong572's Avatar
Bushong572
I have the LPE covers also.........You might try a search, I saw a post last year where someone cut the top 1/3 off with a bandsaw (he said it was easy....looked good). I know the LPE and Callaways are high, but they sure look nice. Good luck.
Old Jan 27, 2008 | 11:34 AM
Bushong572's Avatar
Bushong572
This should help.........
http://forums.corvetteforum.com/show...el+rail+covers
Old Jan 27, 2008 | 01:25 PM
mcv's Avatar
mcv
Here are pictures of the Callaway covers for 2005-2007 Corvettes with Magnachargers. They're molded from fiberglass, not cut-down stock covers.
They have steel mounting brackets bonded to the back side and come with OEM grommets and extra coil bracket standoffs for OEM-like installation.
Part No. 210.60.3048
Sugg. Retail Price: $480.
They're available at Callaway Authorized Dealers, or on Callaway's Online Store.
The Callaway decals come only on Callaway Corvettes and C16's.
Old Jan 27, 2008 | 02:52 PM
jleonhar's Avatar
jleonhar
Thanks for the link. I just completed cutting them like Marct6444 did and they pretty good for a cut down piece. Now I can wait a bit before buying the Callaway covers (expensive). I am so inspired now I may just clean these up a bit more, give them a shot of Millennium Yellow and see how they look. Sounds like a next weekend project. [/font]
Tips for others who may be in the same boat[/font]
1) be aggressive and do not be afraid to cut allot off. I ran the cut line at the bottom of the corvette embossed section taking off at least 1/3. They now just say LS2. Band saw would work best; I used a coping saw and did it by hand. Cleaned up with a Dremel tool. [/font]
2) The hole for the stainless line needs to be expanded as the line shifts back to the rear. Just follow the current line down to make a larger square opening. [/font]
3) You need to cut some off the front to fit it past the power steering tank. About 1 1/2 inches does the trick[/font]
4) On the front of the driver’s side you must trim a little to clear the cables. Just cut the corner down about an inch. [/font]
5) it is held on only but the two mounts now but it seems very solid. [/font]
I still need to clean mine up but I am going to wait until they come off again for paint. Thanks for all of the help on the forum. If I could figure out how to post a picture I would.
Old Jan 27, 2008 | 07:49 PM
Gene Gorman's Avatar
Gene Gorman
Here is a picture of mine. Cut down silver carbon fiber from TKO.
[IMG][/IMG]
[IMG][/IMG]
Old Jan 29, 2008 | 03:38 PM
vvette_c6's Avatar
vvette_c6
www.magnacharger.com
Old Jan 30, 2008 | 01:02 PM
MADMAX1's Avatar
MADMAX1
Originally Posted by 1bdasvt
,I did the same!!
To Calling all Maggie Owners
