C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Does supercharger require additional work?
Old Feb 12, 2008 | 08:23 PM
beanfree's Avatar
beanfree
Default Does supercharger require additional work?
My research says that you need to change the valve springs etc. if you change the cam. I am assuming you do not have to change the valve springs if you supercharge? Out of an abundance of caution should you change the springs? Should you take any other preventive steps?
Old Feb 12, 2008 | 08:34 PM
jogar80's Avatar
jogar80
unless you are putting in a cam you dont really need to change anything. All you need is the supercharger kit and a good tune.
Old Feb 12, 2008 | 08:47 PM
saplumr's Avatar
saplumr
569rwhp and stock block & no internals.
Old Feb 12, 2008 | 10:00 PM
JustLucky's Avatar
JustLucky
Welcome to the best Corvette Forum on the internet!
Honestly it depends on what your goals are for the car. If you are looking for a complete setup, ready to bolt-on, that can make over 500rwhp on the stock bottom end; then I would recommend the Magnacharger system for you. It is a very clean and easy install and makes HP and torque in all areas of the RPM band. It is very reliable and in my opinion gives you the best performance for your valued dollar. The Magnacharger system comes complete with everything you need to bolt-on and go, even the supercharged tune and fuel upgrades are included. There is nothing extra needed to buy besides a different hood as the Magnacharger will not fit underneath the stock hood.
As far as other preventative maintenence/upgrades to go along with any supercharged application, an upgraded clutch is recommended as any stock clutch wrestling with more than 450rwhp is on borrowed time, upgraded output shafts - if you plan to track the car, upgraded exhaust system to expel the spent gases, upgraded shifter to try and keep up with the new found power, colder plugs NGK TR-6's work really well, and upgraded spark plug wires. Do your research before you commit to one kit or another as some kits are not complete and ready to bolt-on as the Maggie is. If you have any additional questions feel free to post them here or PM me. Hope this helps you out!
Old Feb 13, 2008 | 12:00 AM
blownchevy's Avatar
blownchevy
99 % of the Corvette owners out there install a supercharger and drive the car. You need to consider your goals for your car i.e. performance and pocket book.
If you are looking to drive a 100% reliable and fast Corvette, install a Callaway/Magna Charger and forget about it.
Old Feb 13, 2008 | 12:07 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
I'd upgrade the clutch eventually if youre manual.
Old Feb 13, 2008 | 06:51 AM
jleonhar's Avatar
jleonhar
Have a maggie, only routine maintenance I see is changing the tires more often. It is a plug and play kit for sure.
Old Feb 13, 2008 | 07:38 AM
EuroRod's Avatar
EuroRod
I've had my ProCharger for 18 months. Zero issues with it.
Old Feb 13, 2008 | 03:43 PM
DSOMC6's Avatar
DSOMC6
Default Yes upgrade the springs etc
If you are adding a supercharger I would definately upgrade to a quality double valve spring, retainers, push rods, etc. It is cheap insurance.
The issue you face with the weaker stock single valve springs when adding boost is the added pressure may/will force the valves to stay open (will not close entirely) at high rpm . This will cause major problems.
Old Feb 15, 2008 | 06:30 AM
EPP's Avatar
0EPP
Former Vendor
Check out our before and after results when we installed an ATI ProCharger P-1SC-1 on this bone stock C6. http://www.exoticperformanceplus.com...Car.php?car=30 Bob
Old Feb 15, 2008 | 04:21 PM
beanfree's Avatar
beanfree
I am coming from BMW land. My last project was a highly modified 4 door BMW 330i that was dyno'ed at 310rwhp, 250 rwtq on a mustang dyno. Car does have numerous ****ling driveability issues and I am trying to avoid that in my next car.
Loved the ASA supercharger that is on the 330i but the other mods really affected driveability. Car runs mid 13's in the quarter. Might do very high 12's with a good driver.
Wanted to get a real fast car.
Choices: 1. Supercharged LS3 (prefer centrifugal s'c'ger for the more linear power delivery) with no other power mods (no cams, headers, ported intake etc.) but coilovers, good tires (after widebody conversion) or,
2. z06 with mild cam and coilovers.
I am not looking for crazy power. Seems like anything over or near 500 rwhp is plenty for the street.
So any advice on which way to go Z06 or ls3 supercharged?
Old Feb 15, 2008 | 07:09 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Most of our SC installs are on bone stock cars, the list of upgrades from there depends on your projected useage. Drag strip use- then a clutch might be in order soon, road course- added coolers, street use- just go and enjoy it!!
Old Feb 24, 2008 | 10:54 PM
beanfree's Avatar
beanfree
There would be some drag strip use and some auto-x and track use. Mostly going to be for street use. What coolers would need to be added?
To Does supercharger require additional work?
