catch cans
Just ask questions if you want more info. The PCV system on our cars is the most misunderstood mod there is & far to many are done wrong. There is even a tuner out there plugging it all off & running open hoses from the valve covers down to the ground where they suck up dust/dirt/water/gravel & who knows what else directly into the valve train!
Slowly destroying the engine.Last edited by R50THC5; Apr 17, 2008 at 05:32 AM.
http://www.mikenorrismotorsports.com...atch_Cans.html
Hope this helps.
Mike Norris
Hope this helps.
Mike Norris
The longer the line the more chance you have of blockage on either line .
As the line droops and rises , everywhere the line droops oil will settle .
Ya gota remember , oil is heavy and you can only push/pull it uphill and downhill so far with the vacume of the motor , it will settle at the lowest point .
Its only a matter of time before that catch can mounted by the brake booster with 3/8 id lines that run around the back of the motor clogs up and becomes useless .
Ask me how i know :P
The can is black on black so you can not see the detail, but should give you an idea on what you are looking at.Mike Norris
The Procharger installation manual I got with the unit instucted us to cap off the intake manifold port with a cap (I have the boost switch for the methanol injection and Boost-A-Pump connected to this port, but it does not connect to other crankcase venting.) The PCV (valley) port is to 'T' off to the passenger side valve cover vent port, and the other connection hose is to connect to the Procharger intake air filter. This routing makes me wonder where the cleansing intake air is to come from.
On your installation photos, am I correct in that you have the catch can installed as it would be on a non-forced induction car, that is with the PCV valley port connection through the catch can to the manifold intake port? Did you install a pressure check valve inline with the manifold line, in order to prevent reverse flow?
What is the correct way to install a catch can on a F/I car? Some mentioned using the intake manifold connection (with pressure check valve), and others mentioned not using the manifold port.
Any insight would be greatly appreciated.
On any forced induction car with or without my catch can there should be a one way check valve in the PCV hose. I know APS supplies one as does Andy with the A&A kits and most likely a few others. I know some do not and not sure why. I know the PCV valve will hold some pressure, but can not be depended on for a complete seal.
My can does not have such a valve built in for the above reason in that it should be part of any FI kit out there. If one is not used it can be sourced rather easily.
On the breather hose that goes to the air duct on the C6's or the port on the TB, it does get blocked of per all FI instructions I have seen and from there a couple choices.
One is to just add a breather as shown which has a down side of getting oil fumes at times due to the oil vapors being let out to the atmosphere. This can also leak if the element becomes full enough of oil.
Second is to run the factory breather to the inlet area where there is no boost. With a proper check valve in the PCV and good ring seal, this should work fine. In situations where oil is still getting into the intake tract via the breather hose due to boosting the crankcase, you can put a second catch can in the breather line also.
I am just not a big fan of using an external breather due to the fumes on a daily driver, but it some cases it is needed or just less expensive.
Hope this helps.
Mike Norris
Hope this helps.
Mike Norris
