C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS3/LS2 Compatability
Old Jun 21, 2008 | 09:50 PM
dmawd's Avatar
dmawd
Default LS3/LS2 Compatability
Thinking of mods for LS2 and then down the road putting back to stock at sell time and moving the parts over to a LS3. So my question is will any of the options listed be able to work on both engines?
1. Procharger
2. Paxton/Novi type DS1/DS2 etc
3. Maggie
Thanks in advance guys
Old Jun 22, 2008 | 01:54 AM
blu00rdstr's Avatar
blu00rdstr
I used my LS1/6 A&A kit for my LS3 (C5). The only thing I had to do was flip the throttle body over and space the power steering reservoir out 1/2", and trim the reservoir bracket.
Old Jun 22, 2008 | 04:41 PM
excessive81's Avatar
excessive81
intake is diffrent so maggie will not work. any centri will swap just fine
Old Jun 23, 2008 | 12:19 AM
o0 zeno 0o's Avatar
o0 zeno 0o
1. Procharger
3. Maggie
Maggie won't swap unless you put LS2 heads on it.
Procharger has actually made some noise about not using their LS2 kit on LS3's, but people have done it. Their the one's who make the DS1 by the way, unless your talking about something I'm not familiar with. The Paxton from ECS is a Novi-1500.
I would give Andy at A&A or the guys at ECS a call... I think they both both have folks running their kits, and I think they would both be willing to help you figure out the swap when the time came.
Or better yet, bounce your ideas off your local tuner in person. Sometimes it's easier for them to feel out what you really want when they can talk to you face to face, and you may find what direction you really want to go by hearing their full explanation on things.
Old Jun 23, 2008 | 10:33 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Like others have stated, our Paxton kit can be switched from an LS2 to an LS3 with just a different inlet/MAF duct. At that time we can set you up with that very easily.
Old Jun 28, 2008 | 09:17 AM
excessive81
procharger kt is same except the inlet pipe....you will need to swap that so ls3 maf will fit...but if you are retrofitting a ls3 into a older car that not going to be an issue
Old Jul 3, 2008 | 02:20 PM
Max@Cartek's Avatar
Max@Cartek
A centrifugal charger setup is the way I would go. Easy to move over.
Call us if you have any questions.
Max
908.317.4496
Old Jul 3, 2008 | 03:43 PM
4evervette's Avatar
4evervette
so every one knows..how about ls2/3 to ls7 vice versa ??!
To LS3/LS2 Compatability
