Wet shot, got some ??
So, in summary... tuning, tuning, some more tuning.... and when you are done, some tuning!!!
Yeah, vacation what?
I think I now know my strategy of attack. For sure i'll get a H/C package with supporting mods, including TR6's. That will put me in the 580-600rwhp mark. Also, that would be good for mid 10's or better. On top of that, I'll hit it with maybe a 100shot to get it going well into the high 9's. Of course, i'll need tires, clutch, etc.
But what about injectors at that power level... I haven't the slightest idea what my duty cycles are now, but at that power level (est. 700rwhp) I think I'll need a better injector and maybe a BAP.
Your thoughts?
Matt
I'd say a more reasonable expectation is 550-560 RWHP and 520ish Ft. Lbs of torque if you do all the right things (on pump gas). However, I digress. As stated earlier, it's all in the tune!
Oh, and your stock injectors will be fine with the heads/cam/header setup as long as you run a wet shot.
I've made over 1,000 ft. lbs of torque on the setup I mention above (With a wet shot) and on a STOCK BOTTOM END (and on 93 octane)!
Oh, and you'll be amazed at how well your stock clutch holds up (on the street) until you take it to the drag strip.
Good luck and let us know how it all turns out!
