TwinScrew Vrs. Centrifigual
John
John
In 6th gear at 1500RPM, I have circa 300ft-lbs torque at the wheels, via 0.57 reduction
In 5th at 1750RPM circa 330ft-lbs via .71 reduction
In 4rth at 2500RPM 375ft-lbs via 1:1 drive ratio.
In 3rd at 3750RPM 460 via 1.43:1
In 2nd at 5250RPM 518 via 2.07:1
So torque delivered to the ground at 60MPH becomes:
6th: 171ft-lbs => It will accelerate like, say, a Honda Civic in 2nd.
5th: 234ft-lbs => It will accelerate like a decent family sedan would in 3rd.
4rth: 375ft-lbs => It will accelerate like a stock C6 would in 3rd.
3rd: 658ft-lbs => It will take off hard.
2nd: 1072ft-lbs => It will most likely blow the tires off and go sideways. When it hooks up, the radar detector usually pops off the windshield. At that point, the car will not stay in gear for more than 1 second before it hits the rev limiter.
The point here being that with most of your torque arriving at the upper half of the power band, you will be forced to downshift more gears more often in order to harnes that spectacular FI acceleration you seek.
Now we run the same math for an LS2 equipped with a Magnuson MP122. This car made 561RWHP / 490RWTQ. A mild Twin Screw car would post similar numbers with less of a drop off in torque at the top.
Below are approximate torque numbers delivered at the wheels, with the difference in parenthesis:
6th: 200 ft-lbs. (+30)
5th: 284 ft-lbs (+50)
4rth: 445 ft-lbs (+70)
3rd: 672 ft-lbs (+ 14)
2nd: 993 ft-lbs (-79)
The positive displacement blower makes the Roots car act like it has a much bigger engine. With the additional low end torque it pulls harder and cleaner in higher gears, and does not need to shift as often.
However, it falls off up top. In a race where shifts are occuring at 6500RPM, the Magnuson car would lose every time. On the street, where most people aren't redlining their engines on every shift, it may be more pleasant to drive. This may explain why Callaway and Lingenfelter only offer roots as their supercharger of choice, and why Mercedes Benz, BMW, Ford, Pontiac, Mazda, Toyota and others all chose roots or twin screw blowers as their OEM offering for supercharged cars. The Centrifugal is more efficient, and it will make more power with less parasitic drag and less heat than a roots, but on a street vehicle that is sometimes not the main consideration. *I* would still chose a centrifugal over a roots any day, but what I want from my car may not be what you, GM, or maybe even the majority of Corvette buyers is looking for.
Now when you look at the Twin Screw, the decision becomes tougher... They are about as efficient as a centrifugal and still make the low end of a roots. It all depends on what you want... For me the aftermarket hood and extra cost of the twin screws has always been a bit of a deal breaker, but they are a better supercharger design; you get about the same efficincy as a good centrifugal, but with a lot more area under the curve since boost comes on right away and stays there.
Of course, as you pointed out, in the first gears all that low end torque really starts to work against you as it becomes nearly impossible to get traction on regular street tires. The point I am making is that we have 6 gears... Somewhere on that shifter all cars get traction, and when that happens, you can ALWAYS use more torque and more horsepower
To the OP, you definitley need to drive any combination you can. No one can make the choice for YOU. Good Luck
My Maggie blown Vette with cam,headers,smaller pully,meth,etc will kick *** on most other blown Vettes off the line!!
If you can run some R compound tires or run DR's, that is the only real way to enjoy the low end power.
These centrifugal vs. everything else threads get old..... I've owned both and you really can't lose with whichever you decide. From my last trip to the drag strip though, I didn't lose.... centrifugal C5 Z06, 402 stroker C5, 500 rwhp C6 Z06.
To give you the best advice, you need to let us know how you plan on using your car. Drag strip, street, etc...
A roots will not match the peak power a centri is capable of. I just wish some people (not you PowerLabs)would learn that the system that makes the most peak power is not the best for everyone. I've owned a centri car and have driven many others. I would not buy another centrifugal....I just don't like the power delivery compared to a roots or twin screw....but I know many people that love theirs.
75% of the modified vette owners I know don't even race their cars......they built them just for fun. I think the best advice we can give someone with the "which is better" question is to do the research and drive what is available.
Just my .02
I know Vortech,Paxton,and other blowers make a good amount of power,,but from My experiance with My Maggie Vette,and what My other Vette Bros with Maggie's have aggred on is that our Maggies have killer tq off the line{more at lower rpm's},and yes,the other blowers will have plenty,if not more hp as well than a Maggie can make!
I see You have a Vortech blower and Your making 15 or so more rwhp than Me on the dyno,,but Mine's an "auto" with a high stall converter AND lower gears so I think My #'s are pretty good for a Maggie!!
Enjoy Your ride and I like the way You always put up a well written post!
George
Just my .02
I could just as easily have created another exaple where both cars are launched from 4500RPM clutch drop and shifted at 6700RPMs, thus only riding in the 4750 - 6700RPM range... Now the relevant powerband for the centri car becomes 510ft-lbs to 480ft-lbs while the maggie makes 490ft-lbs to 430ft-lbs in the same range; the centrifugal car wins. Does that make it a better system? Sure, if you are building a car to drag race, or if you drive shifting at redline all the time... I think that's what most people think about when they claim centrifugal blowers are "better", but realistically, most people don't drive like that
I came into Corvettes from a couple of small engined, high strung, 8200RPM + redline turbo cars... My Impreza made 100ft-lbs of torque untill maybe 3200RPM or so.. There was NOTHING there until the turbo spooled. Then it took off and was super fast so long as I kept shifting it at redline... My C5 Z06 was a lot peakier than the LS2 also... I feel right at home with the centrifugal blower; the low end plenty good, and the top end is a huge rush... But I would love to try out a Maggie some time; I am sure they are spectacular setups and I know there is a very good reason Callaway and Lingenfelter use them...
And I also think that with the addition of the new TVS from Eaton and Kenne Bell's Twin Screw kits for the C6, positive displacement superchargers are going to become a lot more popular
Ultimately, we have to remember that if one system was clearly superior to all others in every possible scenario we wouldn't have so many options... The reason you can go out today and get a stroker, a turbo kit, a rear mounted turbo kit, a paxton, vortech, procharger, magnuson, kenne bell, etc etc for your car, is because each one of those systems excels in their own right... It is up to each driver to evaluate his budget and intended usage and find out which system is best for him
George
Your numbers are fantastic for a Maggie... My comment was just because a lot of times when you try to make any kind of comparison between different systems, people take it as a challenge, and then the thread just degenerates into who has the "best" system, and no one really learns anything...
I really like doing these comparisons not to find out which one is best, but rather to see how different systems differ... Unfortunately any time I pitch any given system against another, it has a tendency to go really bad
From experience: If I use my Vortech as a benchmark, someone will show up and say I am bragging. If I use anything by ECS, and then say it is anything short of god's own chariot, hoardes of ECS consumers and employees will show up and say that I'm bashing them and I don't know what I am talking about. If I compare a blower to a heads and cam car, the heads and cam fans will say I don't know what I'm talking about because H/C cars are faster with less power, and don't heat soak etc etc...Oh, and if I quote a book, someone will show up and say that book examples don't work in the real world... If I use math, the response is usually the same.
If I use a different car as an example, someone will say that the example doesn't apply to Corvettes, like somehow the power and torque these cars make is wildly different from all other vehicles
But if I don't use real world examples for comparison then it just becomes hearsay and personal opinions... I'll say my car is "pretty fast" with a centrifugal, then someone will say that their car with a stroker and a nitrous shot "beats all the centrifugal cars at the strip", so that must be better, then someone else will say that their maggie car "beats strokers at the standing mile" and then we may all just line up against a wall and see who can pee the highest
I have found that the only sure way of not getting bashed on this forum is to give nothing but thumbs up or cheers at threads, not ask too many questions, specially to any vendors, not make comparisons, and never say anything negative about any mod or any system... Its a shame I don't work like that, because I've offended and upset enough people here with my posts that I hardly even start new threads any more.
My (under hood) list:
D1SC Set @ 7 PSI
Mild Blower Cam (for low end torque)
Dual Valve Springs
Booster Pump + Extra Fuel Line
American Racing Headers w/Hi Flow Cats
Manifold
160# Thermostat
Borla Exhaust
Dewitts Radiator
A conservative tune
......and many more
I am not sure what you want to do with your car but my wheels spin thru 3rd gear and the car pulls VERY hard through 170 MPH (my top speed yet). I also added Nitto Invos and they provided much improvement related to ride quality and grip. I have never been in a roots/twin screw car but I am sure the result is similar - I am no expert ,as is Power Labs, but with FI your wheels will spin.
If I blow up my engine or my transmission fails - I can upgrade
