C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
reduced engine power - early boosting?
Old Dec 7, 2008 | 04:02 PM
zeshawn's Avatar
zeshawn
Default reduced engine power - early boosting?
Friends car
Set-up is a MN6 LS2 + M112 @ 9-10 PSI of boost. Engine is also cammed, otherwise stock.
Stock fuel system, 60lbs injectors.
The car was always fine, the last change involved moving from catless 1 3/4 to catless 1 7/8 primaries including a 3inch x-pipe + changing the CAI from a vararam to a callaway honker.
its worth mentioning that the crankcase evac hose that connects to the intake isnt installed, HOWEVER there is absolultey no way that could cause the problem
Problem appears under full throttle, check engine light comes on, reduced engine power, and the car disengages the throttle, applies the briefly applies the brakes, when the car comes to a stop, it vibrates like anything.
Turning off the vehicle for a minute solves the problem, just for it to re-appear again after another WOT run.
Reading the code says "Reduced engine power - Early Boosting"
any ideas?
I never knew an M112 can boost an LS2 up to 10PSI
Old Dec 7, 2008 | 04:33 PM
tjwong's Avatar
tjwong
10 PSI is quite high for a MP112, are you sure that your gauge is correct or if it was calibrated. Many off the shelf AutoZone special and I have even seen Autometer manual type boost gauges that were way off. Most of the time their electronic gauges seems to be much more accurate.
As for your issue of getting a CEL lamp and reduced engine power have you checked to see what DTC is stored. I would bet that its air flow issue where the PCM is seeing too much air so it errors out thinking that there is a throttle body issue.
Check your engine cal. If you are using Hp Tuners you can check the Engine Diagnostics, then click on General tab, make sure that the airflow vs RPM table has been changed from stock, also Min ECT constant to enable the tests for P101, P106, and P121 has been raised so that the PCM doesn't perform the test. Those tests are for throttle body performance tests. If it sees high MAP, Air flow errors etc, it thinks that the ETC throttle has wacked out and will cut the throttle control. If y ou are using a canned tune from Callaway or Magnusson these parameters should have been changed already.
Old Dec 7, 2008 | 04:41 PM
zeshawn's Avatar
zeshawn
Thanks for the response bro, that was useful.
It was a canned tune from LPE, and the car ran fine before the header, CAI and x-pipe swap. No idea how would such things cause this problem.
Again, when we face the problem, the car idles VERY roughly and vibrated all over the place, which is weird but well check the parameters you suggested.
Anyone else?
Old Dec 7, 2008 | 05:11 PM
Mr.Big's Avatar
Mr.Big
Originally Posted by zeshawn
Anyone else?
It is an airflow issue as mentioned, if running HPTuner install the /maf patch asap... is the car a 2005???
Old Dec 7, 2008 | 05:16 PM
Mr.Big's Avatar
Mr.Big
p.s, Shawn, if you search through Threads by me (Mr.Big) using the "search" feature I've written a BUNCH of threads pertaining to this... If more help is needed go back and read through those posts, you will find your answers and then some...
Old Dec 7, 2008 | 05:28 PM
zeshawn's Avatar
zeshawn
not a 2005, and sorry that MN6 was a typo its an A6, does this still mean if could be due to the HPT maf patch?
Old Dec 8, 2008 | 12:04 PM
IPS Motorsports's Avatar
IPS Motorsports
what code is it throwing 6060?
Old Dec 8, 2008 | 09:00 PM
FunCool's Avatar
FunCool
Friends car
any ideas?
10lbs is nothing!!! On my LS2 402ci with a 112 maggie I have made 18lbs of boost. Look at my signature for dyno video!!
To reduced engine power - early boosting?
