C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Nitrous Progressive controllers?
Old Dec 17, 2008 | 07:25 AM
wanalooz's Avatar
wanalooz
Default Nitrous Progressive controllers?
If a car is set up with a direct port 300 shot with a progressive controller can it be switched to a 100 shot in a push of a button? Can it fluctuate that much? Also can you have a separate curve per gear?
Thanks Ed
Old Dec 17, 2008 | 07:34 AM
chuntington101's Avatar
chuntington101
i dont know but it sounds like a killer setup!
Old Dec 17, 2008 | 12:50 PM
CODE4LS1's Avatar
CODE4LS1
Well, 100 HP is 30% on your progressive controller so it shouldnt be a problem.
Old Dec 17, 2008 | 03:27 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Correct as code4ls1 said, just set it for 30%. If going progressive stay on top of solenoid maintance as one run wears the noid like a full season of runs on a regular solenoid. A better way way would be to just re-jet the size hit. That's why I like multi stage better, less wear and tear on the system. Now if we just progress a bit to get off the line, that's fine, like 30% to 100% in .5 seconds.
Robert
To Nitrous Progressive controllers?
